Need Opinions of Turn Down Tail Pipes >
Old 10-07-2007 | 01:02 PM
CcanDo's Avatar
Default Need Opinions of Turn Down Tail Pipes
The application includes approximately 1,000 HP and 600 CI turbocharged,idling at 1,000 -1,100 RPM...Drivelines and transmissions (for length puposes) ....What is your metod of choice for quieting the exhaust. Also, your preferance of tail pipe diameter.
Thanks for any input !
CcanDo is offline
Old 10-08-2007 | 07:04 AM
GLH's Avatar
GLH
Mine are 5" pipes running 653CI Zul's with blowers... I like them very usefull at idle and still screams when your running...
Trick marine had them Custom Built with measurements from a work sheet they provided and I sent them.
Attached Thumbnails Need Opinions of Turn Down Tail Pipes-dd1.jpg   Need Opinions of Turn Down Tail Pipes-dsc00654a.jpg   Need Opinions of Turn Down Tail Pipes-dd3.jpg
GLH is offline
Old 10-08-2007 | 07:13 AM
cosmic12's Avatar
I didn't get to hear them idle the other day ( because all the other boats were running) But I did see that they are above the water when sitting still, I thought they were supposed to be under untill on plane. Buy the way the boat looked great.
cosmic12 is offline
Old 10-08-2007 | 07:20 AM
lightspeed's Avatar
I Have Them On Mine 598/800 Hp Under water till you got on plane still pretty quiet cause they face the water and the sound gets muffled a little, but still loud enough
lightspeed is offline
Old 10-08-2007 | 04:18 PM
CcanDo's Avatar
Thanks Guys !
CcanDo is offline
Old 10-08-2007 | 07:06 PM
OldSchool's Avatar
I'll give you the other side of it. I just removed some 4.5" turn downs from my boat. They worked flawlessly and were quiet when not on plane, but would soak about the back 5 feet of the swim platform from the spashing. On plane, they were quieter than before (Stellings dry pipes) and had no effect on performance. If the PoPo were enforcing noise laws around where I live, they would still be on my boat....but they don't and I'm loud as chit again. My neighbors love me.....what can I say?????????????:ernaehrung00 4:
OldSchool is offline
Old 10-09-2007 | 06:44 AM
GLH's Avatar
GLH
I get a bit of splash back also but not enough to be annoyed about.
Also I run my boat I don't just use it to pose on idle hours on end like some Civil Servant...
GLH is offline
Old 10-09-2007 | 07:13 AM
Sydwayz's Avatar
Forum Regulator
The hole goes down Craig. Were you trying to make your Cig look like a Yammie PWC?
Sydwayz is offline
Old 10-09-2007 | 07:23 AM
OldSchool's Avatar
It didn't annoy me, it annoyed Nancy.......everytime that she went back there to attach lines. If Nancy aint happy....well, you know!
[/QUOTE]
Also I run my boat I don't just use it to pose on idle hours on end like some Civil Servant... [/QUOTE]
I'm not known to take it easy on my chit!!
Old 10-10-2007 | 03:34 PM
CcanDo's Avatar
I'm leaning toward using the turn down pipes....Thought about asking Stelling for pipes with GGB ? inline mufflers...Randy provided a good quote,though he doesn't have a CMI flange ring...customer furnished item...Unknown burn through in the mufflers and then potential reversion bothers me a bit.....I'm not sure the Stelling ---GGB combo will pass the DB test ...Maybe someone here knows.
CcanDo is offline
