Tundra brakes live up to their name >
Old 10-13-2007 | 09:00 AM
jonyb's Avatar
Default Tundra brakes live up to their name
jonyb is offline
Old 10-13-2007 | 12:55 PM
Formulabill's Avatar
Looks like not enough MULE to safely pull and stop the wagon.
Formulabill is offline
Old 10-13-2007 | 01:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Those look like those ratchet permanently attached rear tie downs. Can anyone confirm?
If he has airbags installed, I bet he can just drop the trailer, and head on down to the launch ramp.
Sydwayz is offline
Old 10-13-2007 | 01:30 PM
jonyb's Avatar
ah no, haven't you heard? Have you not seen the commercials? Tundra's are great for towing heavy loads
jonyb is offline
Old 10-13-2007 | 01:47 PM
Sad thing is the Jackass that caused all the trouble probably just drove away at half the speed limit .
1bagger is offline
Old 10-13-2007 | 03:29 PM
offshoredrillin's Avatar
looks to me that the brakes worked fine, seems that quality tie down job of the poontoon was the problem.
offshoredrillin is offline
Old 10-13-2007 | 05:49 PM
24degrees's Avatar
What about that is the truck's fault.........
24degrees is offline
Old 10-13-2007 | 06:36 PM
UNSANE's Avatar
Had the brakes been crappy, I think the pic would look a little different. Looks like to me the brakes worked TOO well in this instance.
UNSANE is offline
Old 10-13-2007 | 07:42 PM
BUIZILLA's Avatar
instigator
look closely...
he rear ended someone, front end is gone too.. probably hit the guy standing next to the trooper, and that's his rig at the furthest back of the pic.. look's like a Florida Trooper
BUIZILLA is offline
Old 10-14-2007 | 05:33 AM
jonyb's Avatar
Guess I should have noted my sarcasm in the first of this thread. It's obvious that the brakes on the Tundra didn't create this problem.
jonyb is offline
