Why are Surface Drives So Expensive? >
Old 10-13-2007 | 09:45 PM
Default Why are Surface Drives So Expensive?
Surface drives look simple enough, basically a drive shaft going through a tube with bearings. They certainly look less complex than an outdrive. Yet they are several times more expensive than most outdrives (#6 drives excluded), and the props are in some cases near 10 times more expensive. Even the non-articulating surface drives, with a rudder for steering are expensive, yet I can't think of anything simpler. Maybe someone can enlighten us.
Michael
Michael1 is offline
Old 10-13-2007 | 10:09 PM
Smile
If Mercruiser would sell the same number of drives as Arneson and the others combined ,
they would cost much higher as well .The bronze Arneson models's cost make more sense though .
I've made my own scale Arneson for my Prather back in the early 80's , because there was none produced at that time . Here's the model
Today you can even buy # 6 drives
spectras only is offline
Old 10-14-2007 | 01:13 AM
Default Awesome
Used to have a small shockwave 36 ,, awesome job on the arneson that is cool
johnfharding is offline
whoosurdadi
06-18-2007 01:26 PM
imongo
17
11-07-2002 10:19 AM
kingpin
10-01-2002 11:02 AM
