Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
transom costs.... 32 Baja. >
Old 10-14-2007 | 06:23 PM
Full Force's Avatar
Default transom costs.... 32 Baja.
I have a 86 Baja 320 force, I bought the boat a month or so back, I knew it would need transom work, now I hurt an engine and I will be pulling both to freshen them, well I guess this would be the time to do the transom! Anyone have any idea average cost is to do a transom if I remove engines and gimbles myself? From what I can tell the stringers are good, all sound solid with a hammer test, transom is soft between the drives, the rest seems fine also.
Anyone in Northern Ohio???
Full Force is offline
Old 10-14-2007 | 09:45 PM
'05 Concept SF23
Check with Glass Dave on here. He is in Toleado
f311fr1 is offline
Old 10-15-2007 | 04:58 AM
Full Force's Avatar
I talked to him on Labor day, I am just trying to get more opinions too.
Old 10-15-2007 | 07:03 AM
Audiofn's Avatar
Charter Member #232
I would think that if you stripped it totally for a glass guy that you would be looking at about 2-3 grand depending on the extent of the damage.
Jon
Put your best foot forward!
Audiofn is offline
Old 10-15-2007 | 05:34 PM
Full Force's Avatar
Jon
I will be stripping it all myself, I would be taking them a bare hull, I was all over it today with a screwdriver tapping stringers, somehow they all sound great, all the way to the transom.
Old 10-15-2007 | 08:11 PM
tripps's Avatar
Check out Transom repair.com,i just did the seacast on my 31 corsa,check out the thread transom repair,i just cut out the inside fiberglass except the 3 inches around the edge,put a piece of plywood in front of the old glass on the outside,spaced out 1.5 inches ,cut rectulanger holes in the deck,made a funnel out of sheet metal,poured the stuff in the transom,removed the plywood next day,glassed it up,and now im mounting the bracket and motas to it ,makeing tie bars to the stringers also. any guestions ?? call me 917 468 3607 got a bravo setup 4 sale also new gimble and pump,older upper and lower too seaya
tripps is offline
Old 10-16-2007 | 02:06 AM
Tripps, can't seem to find your thread anywhere. There are a few threads titled "Transom Repair" there?? Can you point me in the right direction? What name do you go by there?
jez350 is offline
Old 10-16-2007 | 06:37 AM
jeff32's Avatar
3000 is my guess...
jeff32 is offline
Old 10-16-2007 | 04:17 PM
Full Force's Avatar
Originally Posted by jeff32
3000 is my guess...
Thats about where I am at so far.
Old 10-16-2007 | 05:44 PM
tripps's Avatar
look at transom stringer replacement,its the 3rd one down now!!! lotsa imfo there, the web site is transom repair.com check it out!!! tripps
tripps is offline
