how can you marinize an aluminum block >
Old 10-16-2007 | 10:08 AM
Default how can you marinize an aluminum block
have the new merlin x aluminum bbc block and would like to marinize or coat the water jackets to keep from corroding . For fresh water use only, but need to know who can do this for me.
badbug is offline
Old 10-16-2007 | 01:16 PM
Have it anodised. That's what many if the intake manifolds have done to them.
Darrell.
DMOORE is offline
Old 10-16-2007 | 03:40 PM
do they discolor the outside of the block along with the water jackets?
badbug is offline
Old 10-16-2007 | 06:39 PM
monstaaa's Avatar
annodizing is a dipping method of coating material, so yes. and if its fresh water i wouldnt sweat it too much.
monstaaa is offline
Old 10-16-2007 | 09:54 PM
Yes, but you can do a clear anodizing. But like MONSTAA said, if it's a fresh water boat, don't bother.
Darrell.
DMOORE is offline
Old 10-17-2007 | 07:53 AM
anodizing also hardens so many thousandth's.
excalibur32 is offline
Old 10-20-2007 | 08:15 PM
Sydwayz's Avatar
Forum Regulator
There are issues with running (sea) water through/around cast aluminum IF your water has a negative ion charge, as in if its used to cool a nuclear power plant, or something along those lines.
I've been there, not with boats, but with hi-po PWC parts.
Just an FYI.
The negative ion charge will break apart the cast aluminum at the atom/electron level.
Sydwayz is offline
Lmarth
3
12-22-2007 01:08 PM
MidnightRider
08-02-2007 06:35 PM
tomcei
24
01-02-2007 05:16 AM
gripit
9
11-25-2006 06:38 PM
timucin
8
09-29-2002 11:43 AM
