How Much Diffuser Ring to Cut Off? >
Old 10-21-2007 | 11:22 PM
Rebel_Heart's Avatar
Default How Much Diffuser Ring to Cut Off?
I have a pair of labbed P5Xs (31s). Would still like to get some additional rpms. Should the diffuser ring be cut off? A portion cut off? Or, look for another place for rpms. Right now planing is not an issue. Looking for 2-3 hundred rpms.
Rebel_Heart is offline
Old 10-22-2007 | 12:06 AM
I've heard that the rpm gain of cutting off the diffuser ring is 50-100rpm.
Griff is offline
Old 10-22-2007 | 06:40 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Griff is correct. We often see even less with the Hydro.
[email protected]
bbladesprops is offline
Old 10-22-2007 | 08:40 PM
why is it typically cut off ? And what is its purpose ?
tomcei is offline
Old 10-22-2007 | 09:57 PM
Slight speed gain and may slightly reduce bow lift. It can make getting on plane very difficult in some cases.
Griff is offline
Old 10-23-2007 | 08:44 PM
Smile
RPM gains to be followed by mph gains.
Actually the reduction of the diffuser can increase bow lift. Planing is the key issue.
[email protected]
Old 10-23-2007 | 10:58 PM
Brett - I sent the props off today. After talking with you, I decided to have it done yet this fall. I left a note in the box to check my file. We spoke of the difuser ring along with some other modifications.
Thanks, Brett. Let me know if you find anything else that needs to be done.
Rebel_Heart
Prop Talk
10
05-16-2008 08:27 PM
JasonSmith
Prop Talk
4
08-06-2007 01:46 PM
JimV
Prop Talk
12
10-25-2006 12:08 PM
Ran-Dom 32
Prop Talk
3
10-07-2006 03:28 PM
zahndok
Prop Talk
7
01-27-2006 02:06 PM
