Deals Drives Drives & Lowers Deals
It's clean up time.
plain and simple this is what we have
1 used XR drive complete - dual water pick up - all black - with
1.50 gears - the upper is hellicoiled and drilled for Imco steering.
******************* $5000.00 ******************
2 used Bravo 1 drives - mid water pick up - drive shower - with
1.50 gears - all black
******************* $2500.00ea*****************
1 used XR upper - hellicoiled and drilled for Imco steering - all
black -
******************* $2650.00 ******************
2 NEW Sportmaster Lowers - satin finish - with 1.26 gears - TCM vertical shaft - TCM prop shaft
*******************$4500.00ea*****************
black -
here are a few more we found or put together for someone
TEAGUE Lower - satin finish - with 1.50 gears - TCM vertical shaft - TCM prop shaft - 2" Short - Satin finished Imco housing
******************* S O L D******************
2 used Bravo 1 drives - mid water pick up - with
1 used Bravo 1 - with drive shower and mid water pick up -
1.50 gear ratio
******************* $2500.00 ******************
1 Used Bravo 1 - with 1.36 gears - Low Water pick up with nose cone
*******************$2400.00ea*****************
1 used TEAGUE Bravo 1 upper - 1..35 gear ratio
*******************$1000.00*******************
1.50 gear ratio
What year/Serial numbers are the Bravo 1's?? also do you have any "X" drives? thanks Mike
1.50 gear ratio
1.50 gear ratio
