86 formula 272  prop help ? >
Old 10-23-2007 | 12:25 PM
Is there any 272 owners that can help not sure what prop i should buy . my boat has twin merc 350's 260 hp stock with alapha drives it runs toped out 49 mph at 3900 is this right or what should i do they are also not ss props thanks.
tom call is offline
Old 10-23-2007 | 07:13 PM
'05 Concept SF23
My 85 272 would run 60 at 4800 RPM with cleavers. You have too much prop or your motors are tired. Also Formula had a performance option that had a higher than normal X height. The early 83-84 models had a fairly big rocker in the hull. Check on the Formula forum.
f311fr1 is offline
Old 10-24-2007 | 03:08 PM
Default formula 272
do you remember what size dia the props were and what pitch? thanks
tom call is offline
Old 10-24-2007 | 03:26 PM
Like F311 said.
Run cleavers. I have them on my 85 Formula 272 LS. 60 MPH.
23" pitch.
PARADOX is offline
Old 10-24-2007 | 07:53 PM
Originally Posted by PARADOX
Like F311 said.
23" pitch.
I would also try A pair of 21 Mirages Or 23 Mirage. My 87 272 would spin the 21's 5000 but i lost 4 mph I ran the 23's Spun them 4500 @59.99999 my cruse was 40 at 3200.
Car Biz is offline
Old 10-24-2007 | 07:56 PM
'05 Concept SF23
My cleavers were 21 pitch. The bravos need to be 3 blade.
f311fr1 is offline
Old 10-25-2007 | 07:18 PM
is there only on dia for these alpha drives or what dia should i use with 23 pich clevers
tom call is offline
Old 10-25-2007 | 07:45 PM
'05 Concept SF23
23 is too much pitch. You need 21 pitch. Contact Julie at Throttle Up. They advertize on here.
f311fr1 is offline
Ran-Dom 32
Wanted
2
10-13-2008 05:26 PM
WaterJunkie
Wanted
0
07-30-2008 05:57 PM
tom call
4
10-31-2007 09:01 AM
kevin285
10-13-2003 09:34 AM
groove
08-12-2002 09:34 AM
