Where To Get Some Nice Looking Numbers >
Old 10-24-2007 | 10:45 AM
Jassman's Avatar
Default Where To Get Some Nice Looking Numbers
Looking for some nice looking hull ID numbers, where I can order them online..Thanks guys. Jeff
Jassman is offline
Old 10-24-2007 | 10:49 AM
Are you looking for vinyl? If so Ryan may be able to help you.
www.KineticAnimation.com
Jim
MOBILEMERCMAN is offline
Old 10-24-2007 | 10:52 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Jeff,
OSO member Kevin Schulte owns www.hardlineproducts.com for a COTS product.
However, if you are going with vinyl stick on numbers for that beautiful boat, you are probably best visiting a local sign/vinyl shop, and having them whip up something custom for you. It should only take an afternoon to do; depending on how busy they are.
As mentioned above, they don't call Ryan Beckly 'Stickerboy' for nothing. He does great work.
If you get in a pinch, call Pat. He has a vinyl cutter in his office.
Sydwayz is offline
Old 10-24-2007 | 11:32 AM
Dean Ferry's Avatar
Veteran: Air Force
I go to the local vinyl guy and have him make them on the spot. He can do some cool things.
Dean
Everything is for sale @ a certain $$
Dean Ferry is offline
Old 10-24-2007 | 11:52 AM
CigDaze's Avatar
I got my last set from Boat-U.S. for about 50 bucks, and I've been very happy.
They have a great online text manipulator with previews.
http://www.boatus.net/boatgraphic/
Here's a sample:
CigDaze is offline
Old 10-24-2007 | 12:17 PM
Jeff,
When I needed the new cat done Jayboat went to nor-tech, checked out the colors and emailed me the design.After approval he went back and installed them. Excelent job and great service.
bellmitsubishi is offline
Old 10-24-2007 | 12:18 PM
baja bailey's Avatar
I just used local place (signs now), they worked with me and the end results were nice...
baja bailey is offline
Old 10-24-2007 | 12:31 PM
Knot 4 Me's Avatar
I like going local as I can see the layout prior to them being cut and can see the vinyls firsthand. I almost always do a slight lean to the letters instead of block and sometimes go a tad smaller than 3" to fit in the area I'm placing the letters. I always go with a two tone drop shadow in colors to match the boat's trim so it is nice to see the colors up front to ensure they match.
Knot 4 Me is offline
Old 10-24-2007 | 01:16 PM
I had a local sign store make a vinyl sign which came out great.
ActiveFun is offline
Old 10-24-2007 | 01:45 PM
Strip Poker 388's Avatar
Rob
Jim
Ryan will take of ya
I had mine made a little smaller and I put them under the rub rail,harder for them to read them
Attached Thumbnails Where To Get Some Nice Looking Numbers-hustler-halloween-04-024-large-.jpg
Strip Poker 388 is offline
