Hydro Lock
Old 10-25-2007 | 07:26 AM
Xray50's Avatar
Default Hydro Lock
Sh--!!!! Starter went THUNK!!!! Pulled plugs. #4 hole full of water. Cranked engive over to blow water out. Put plugs back in, engine ran fine! 2 days later, THUNK! pulled #4, water again. Engine is 540 BBC with IMCO exhaust. Any suggestions before I start pulling parts off?
Xray50 is offline
Old 10-25-2007 | 07:40 AM
tmdog's Avatar
Intake or head gasket.
tmdog is offline
Old 10-25-2007 | 08:07 AM
Xray50's Avatar
Default Ooppss
Sorry, that was #8 hole.
Xray50 is offline
Old 10-25-2007 | 08:08 AM
Xray50's Avatar
Intake or head? Not exhaust side?
Xray50 is offline
Old 10-25-2007 | 08:37 AM
hoozeyurdaddy's Avatar
does the imco exaust have bolt on elbows? if so, go there first and replace the gasket.
hoozeyurdaddy is offline
Old 10-25-2007 | 08:49 AM
Xray50's Avatar
Thanks Hoozey, will do that first.
Xray50 is offline
Old 10-25-2007 | 12:22 PM
Try a riser gasket first. Imco flows water through the manifold riser like stock merc iron manifolds.
Griff is offline
Old 10-25-2007 | 01:06 PM
Xray50's Avatar
That makes sense. With the angle of the engine the water ends up in #8 hole..... going to pull the riser and see if it's round or oval then order one from Imco.
Xray50 is offline
Old 10-27-2007 | 07:26 PM
Xray50's Avatar
Exhaust pulled and pressure tested. Imco manifold and riser is good. Pulling intake manifold Sunday. Sure hope I find a blown gasket.
Xray50 is offline
Old 10-27-2007 | 08:07 PM
Is there water in the oil?
Edward R. Cozzi is offline
