Valve springs (&lifters) for moderate tune-up >
Old 10-25-2007 | 11:18 AM
C_Spray's Avatar
Diamond Member #001
Default Valve springs (&lifters) for moderate tune-up
I'm replacing the valve springs and inspecting the lifters in my Innovation 600's over the winter (300 hours). They are recommending Isky 8005A springs (130# seat pressure; 400 #/in rate), but I have heard good things about PSI valve springs as well. If I've gone this far with the Isky's (8 years), is there a point to stepping up to PSI's, or is that overkill? Oops. - Make that 8005-SP springs, 150 # seat pressure; 415 #/in rate; higher quality wire.
Not sure what spec the lifters (hydraulic rollers) are, but suspect that they are Crane. Any preferences on those if they need to be replaced, and what should I be looking for when I inspect them?
Thanks!
C_Spray is offline
Old 10-25-2007 | 11:59 AM
Thanks!
C-Spray,
Robert Mishko who was with Innovation for 17 years is now in TN about 40 miles from my house. He is "semi" retired but I can check with him if it is okay to give his number out and if it is I can PM it to you.
cstraub is offline
Old 11-29-2007 | 03:53 AM
rmbuilder's Avatar
MarineKinetics
Chuck,
There are three levels of “8005” spring offered by Isky in this series. They all are 1.530” OD / 1.110” ID and fit with no adjustment.
8005-A Standard chrome silicon
135# @ 1.875
395# @ 1.225
400# rate
1.160” stack
8005-SP offers an upgraded outer spring from the above
150# @ 1.875”
435# @ 1.225”
415# Rate
1.160 Stack
8005 Plus offers a PSI/Tool Room outer spring std.
140# @ 1.875”
400# @ 1.275”
420# Rate
1.160” Stack
I have used the 8005 Plus springs and they offer significantly increased cycle value and show very little sag on run in.
Unfortunately the PSI line (being targeted to primarily race applications) offers limited #’s in the O.D., rate, and height required for Hyd-Rollers. There are a few that can be made to work, however with the lift you are utilizing there will be a large area of open coil at full compression.
Smiklos,
Take a walk over to PAC Racing Springs, booth # 4139/4141/4143 at PRI and ask for Chris Osborn. They are really on their game in spring development, particularly the conical. Should save some shoe leather.
http://www.pacracing.com/
Bob
rmbuilder is offline
Old 11-29-2007 | 08:14 AM
Bob, what spring recommendation for gm head #12562934 Gen 6 502 using the crane "741" cam. I'm refreshing after 2 seasons. Thanks.
kennyo is offline
Old 11-29-2007 | 11:04 AM
Wink
Smiklos and RMbuilder:
Guys, talk to me about concial or beehive springs and especially before you Talk to Chris at PAC at PRI !!
By phone or PM please.
Regards,
Ray @ Raylar
Raylar is offline
dykstra
4
08-13-2005 08:29 AM
Summer Heat
2
02-22-2005 03:33 PM
mr_velocity
1
02-10-2005 12:32 PM
BAJA WILL
5
07-21-2003 01:16 PM
BAJA WILL
04-10-2003 09:32 PM
