How Much Speed Do you Think I am losing? >
Old 10-28-2007 | 03:55 PM
seafordguy's Avatar
Default How Much Speed Do you Think I am losing?
How much speed do you think I am losing due to these damaged propellers???
Attached Thumbnails How Much Speed Do you Think I am losing?-cimg2039.jpg   How Much Speed Do you Think I am losing?-cimg2041.jpg   How Much Speed Do you Think I am losing?-cimg2042.jpg
seafordguy is offline
Old 10-28-2007 | 04:28 PM
MitchStellin's Avatar
I would say 50%, those are toast. They will also cause you to loose 100% of your speed when the drive goes, whether it be an out-drive or an outboard you are vibrating bad and that will cause a broken drive. Always carry a spare yo you don't have to run a prop like that, even a cheap one will be better than this. From over revving to vibration to efficiency you are loosing all the way around.
MitchStellin is offline
Old 10-28-2007 | 04:41 PM
seafordguy's Avatar
I have been VERY concerned about Vibration relative to drive wear.
Old 10-28-2007 | 06:23 PM
Shouldn't have used them at all.
MOBILEMERCMAN is offline
Old 10-28-2007 | 06:27 PM
This is a joke thread...right?
Edward R. Cozzi is offline
Old 10-28-2007 | 06:28 PM
what diff does it make
Call TEAGUE and buy a prop for god sake ,you may want to try picking up the drive when beaching,pulling in the marine ,and launch ramps are hungry for skegs & props
good luck
Old 10-28-2007 | 06:33 PM
UNSANE's Avatar
45981734134.2
UNSANE is offline
Old 10-28-2007 | 07:51 PM
now i get it
sschafee01@snet.net is offline
Old 10-28-2007 | 08:32 PM
seafordguy's Avatar
good luck
Yeah - I did it at the ramp unfortunately. 2 ramps and one EVIDENTLY has some Clag or Oyster Shells or something at the bottom. I chose the wrong ramp obviously....
Old 10-28-2007 | 08:43 PM
AKA "BAZOOKA JOE"
Ed i was just thinking the same thing
bojoe2 is offline
