Bravo X question....
First of all I'm a newby to the I/O crew. Been on SnF for the past couple of years with a Mirage and getting into a new territory here. 496 w/ a bravo x... I shut the engine off while in forward.....and now it will not come out of forward.....(yes alcohol was involved) and I was told after the fact that you don't do this to a bravo unit. Is there someway to reset this thing? or do I need to get it straight to the nearest mechanic?
Thanks,
Thanks,
Hook a flushing attachment to it,
turn on the water.
bypass the neutral safety switch at the shifter,
or jump across the slave solenoid with the ignition switch
in the on position.
Make shure everything is clear of the prop
and start it up.
Once running, you should be able to get it
out of gear.
turn on the water.
in the on position.
and start it up.
out of gear.
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
pax2you
3
09-18-2007 09:07 AM
