502 mpi- keep blowing map sensors >
Old 10-29-2007 | 10:11 AM
Default 502 mpi- keep blowing map sensors
How should I test the 3 wires that go into the map sensor? Where does each wire go from the map? Black wire=ground? green=? grey=? The motors starts to run real fat when a map starts to go out. Thanks Matt
poolshrk is offline
Old 10-29-2007 | 08:49 PM
Could use some expert advise.
poolshrk is offline
Old 10-30-2007 | 01:58 AM
mats's Avatar
What is the trouble you experience with the engine?
If the MAP sensor is shot the engine will run but very rich. It will basically smell unburnt gas all over the place. You can try by disconnecting the harness to the MAP sensor and observe the engine. If it runs as bad when you connect the MAP again you do have a problem in the MAP or in the wiring. Also you may get a trouble code if there is a problem with the MAP.
mats is offline
Old 10-30-2007 | 02:08 AM
mats's Avatar
All wires go to the ECM
Gray= 5 Volt reference
Lt green= MAP signal
Black = ground
mats is offline
cass236
2
07-21-2008 01:00 PM
MarkDonzi
1
12-19-2006 08:35 AM
mjb
4
07-01-2005 11:32 AM
Steve_H
11
02-07-2004 05:57 PM
canada
Baja
4
04-12-2002 10:25 PM
