What temp. will freeze a 496HO not winterized? >
Old 11-01-2007 | 06:56 PM
Default What temp. will freeze a 496HO not winterized?
Tonight it is supposed to get in the high 20's and my boat is not winterized. I pumped the system out with the hand pump but understand that water is probably still in the motor. I also plan on lowering it in the water tonight. Is this over cautious or necessary? Thanks for any comments, I am holding out for a couple more weekends of boating.
lakeoftheozarks is offline
Old 11-01-2007 | 07:34 PM
nordic95's Avatar
Put a metal clamp on spot light in the bilge.One 100 watt bulb will keep the bilge about 15 to 20 degrees warmer then the outside air temp.I do this every year and It has worked out great for late season boating.I leave the plug tail of the light hanging outside the cover so when I leave in the morning I just unplug for the day.
Nordic95
nordic95 is offline
Old 11-01-2007 | 07:42 PM
Take a cup with about an inch of water in it and set it on your swim platform if it doesn't freeze you're fine. The lake water is still in the upper 60's so that moderates the temp w/in close proximity a bit as well.
Last spring I put in easter weekend and it got down to 22 degrees that saturday morning. I put one lamp in the bilge and it stayed toasty. I also did the cup on the swim platform and it didn't freeze at all. However I did a cup on my deck and it froze solid. To really be concerned it needs to be below 25 degrees for several hours.
I am coming down either tomorrow or Saturday to fetch my boat and take her home for winter. The season sure went quick!!
baywatch is offline
Old 11-01-2007 | 08:56 PM
Weather channel says its only going to get down to 35* tonight. If you're worried though, shoot me an email and I can run give you a hand draining it. I live in sunrise Beach also.
[email protected]
Brandon
Brandon is offline
Old 11-01-2007 | 09:02 PM
It needs to be in low to mid 20's for the entire night for anything to freeze. Don't even worry about it. It would take 24+ hours in the high 20's to freeze.
Griff is offline
Old 11-01-2007 | 09:24 PM
Plus if he is lowering it into the water like he said, it will take alot longer than that with the warm water temps.
Brandon is offline
Old 11-01-2007 | 09:34 PM
Thanks for the input, I'm just very cautious with this boat since it's my first year with two motors to maintain. I couldn't be happier with the 496HO motors. See ya on the lake next year.
Old 11-01-2007 | 11:17 PM
tblrklakemo's Avatar
SeaRay Sundancer
32... fully winterize it....youve got two to worry about
tblrklakemo is offline
Old 11-02-2007 | 10:59 PM
any one have thru hull pickups? Im curious how to fully winterize and add antifreeze with thru hull pick ups. My boat has both the drive pick up and then thru hulls.
QWKRN U is offline
Old 11-03-2007 | 12:09 PM
Nordic95
After you close the hatch how do you know if the light is on????
Pure Energy is offline
