Bravo 1 to a bravo 3 >
Old 11-06-2007 | 02:06 PM
Default Bravo 1 to a bravo 3
Thinking of switching from a b1 to a b3. Would I use the same pitch on the b3 props as I had with the b1?
CN24 is offline
Old 11-06-2007 | 02:42 PM
Knot 4 Me's Avatar
Your boat's size and motor will determine if you will run a 2.0 or 2.20 Bravo III and that will dictate what prop set pitch you will go with.
Knot 4 Me is offline
Old 11-12-2007 | 10:25 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
There are 4 B3 gear ratios to work with and will need to be concidered with the change. Also, taking into concideration what you currently had for set up and performance numbers.
To sort of answer your question, if you were at the top of the recomended rpm range with the B1 set up, you will probably be able to use the same pitch going to the B3 set up if the gears were the same. But as stated before the gears are different. B3 props are truer to pitch.
[email protected]
bbladesprops is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
