SS Exhaust flaps inetgrated with tips for 454 mag >
Old 11-07-2007 | 12:50 PM
Default SS Exhaust flaps inetgrated with tips for 454 mag
Hello,
I have a regular exhaust with the rubber flaps on the outside. My brother in law showed me in the pipe, up about 4 inches is what seems to be like a little door frame in the middle of each exhaust and he said there were supposed to be 2ndary internal metal flaps hung off of this frame and that they were important.
so I thought i would ask you...
1. Are these important since I have the external rubber flaps
2. If so, where can I find these parts instead of replacing the whole exhaust tip?
thanks! NEW boater Frank
shotjock is offline
Old 11-07-2007 | 01:55 PM
It should have internal flaps. The exterior ones do very little. Where to get the parts depends on what tips you have. They will probably need to come off to replace the internal flapper. try to get internal flappers that are SS. The rubber ones just crack and burn up.
Griff is offline
Old 11-07-2007 | 02:07 PM
Lofty's Avatar
We sell these:
Upgrade your exhaust tips with the absolute best flapper design available. Constructed to be installed inside of SS exhaust tips by welding the mounting pin. Available for 4" tips only.
Attached Thumbnails SS Exhaust flaps inetgrated with tips for 454 mag-100-32_internal_flaps.jpg
Lofty is offline
Old 11-07-2007 | 06:53 PM
Rage's Avatar
Why do the external flaps do very little?
Rage is offline
Old 11-08-2007 | 01:47 AM
Because they float. They open up and water from waves will still get into the exhaust.
Griff is offline
bolgna
4
01-23-2008 06:23 PM
diggin H20
9
06-22-2007 10:49 PM
tssteph
American Offshore
16
04-23-2007 04:22 PM
patrick22309
4
05-02-2003 08:03 AM
blackhawk
08-05-2002 10:27 PM
