msd  timing curve >
msd timing curve
msd timing curve
Old 11-07-2007 | 06:20 PM
ROB FREEMAN's Avatar
Default msd timing curve
how are the rest setting up their msd ignitions timing , spring color , bushing ect just curious thanks rob
ROB FREEMAN is offline
Old 11-09-2007 | 08:22 PM
I did not want to trust the timing to a spring rate, or limitations. So, I choose to use the MSD timing computer.
http://www.msdignition.com/tc_3.htm
Start retard--------total timing retard via chips for that time when premium fuel may not be available. Nice options.
ROTAX454 is offline
Old 11-10-2007 | 03:20 PM
Strip Poker 388's Avatar
Rob
I would use the black bushing and the light/silver springs,then set your total
http://www.msdignition.com/pdf/8360_frm%2023793.pdf
But all my stuff with MSD dist I just lock it out
Also MSD is just starting to powder coat the inside of there dist so they want rust,it might take a while to hit the stores
Strip Poker 388 is offline
Old 11-10-2007 | 07:18 PM
again you come through strip , my engine builder had my msd set with the two large silver and the blue with 32 total i was thinking 598 na one silver small and one blue black bushing 34 total 10.1.to one dart pro ones just want to be safe and not give up too much locking it out been mentioned alot just not sure if that will work for me thanks again guys
Old 11-10-2007 | 11:12 PM
Rob
The only prob I see with locking it out in a boat is detinating it getting it on plane or nailing it below 3000. Also with you at 10.o its a higher chance of det, but I asume you have alumiun heads? you have that chousion
locking it out sure makes it crisp. kinda like krispie ,Rice crispi pops, Snap crackle &pop. Just stay away from the pop
yesme dinking
Old 11-11-2007 | 06:49 AM
jdnca1's Avatar
Run it locked..you will be fine. I have run every boat motor I've had locked with no problems and have many friends who have done the same..
I had a 10.5:1 632" motor with Dart 360's locked, it liked 32 degrees...A friend of mine with a nasty 598" motor had to put a curve back into his last season...why? well when he went to a tunnel ram with (2) dominators he couldn't get the idle down and would be too lean at idle as he droppied it in gear and it wanted to die...well, he put a curve in the motor and it solved the problem...that is the only motor I personally know of that benefitted from a curve...but it was to solve an idle problem from having huge carbs...
jdnca1 is offline
Old 11-11-2007 | 10:15 AM
yesme dinking
yea , dont want nol pop aluminum yes
Donman
13
07-12-2006 06:56 PM
javx2
7
04-24-2006 06:36 PM
mjb
2
09-14-2005 07:27 PM
Hostile Takeover
12
03-01-2005 02:05 PM
John B
5
10-03-2002 06:58 PM
