How long to go through... >
Old 11-13-2007 | 04:00 PM
Indy's Avatar
Member #154
Default How long to go through...
At idle, how long would it take to go through a fuel/water separating filter's worth of fuel? I'm going to put the winterization mixture (2 cycle oil, stabilizer) in the fuel filter but don't want to burn through the oil and into the regular stabilized gas from the tank. Engines are 502 MPIs
Indy is offline
Old 11-13-2007 | 04:07 PM
Ted G's Avatar
Several minutes at idle.
www.cbpba.com
Ted G is offline
Old 11-13-2007 | 04:32 PM
New fuel will still be entering the filter as you run it. Just run it for a minute or two.
Griff is offline
Old 11-14-2007 | 12:36 PM
I found the easiest thing to do is simply mix the winterization formula in a small tank, connect to the fuel inlet, and run until you start smelling 2-cycle oil. It takes longer than you think, at least several minutes at 1300 rpm or so...
I bought this and it works great. Use the left-overs for winter chain saw work...
http://www.overtons.com/modperl/prod...r=view&i=36861
4mulafastech is offline
Old 11-14-2007 | 12:50 PM
CigDaze's Avatar
A typical stock big-block idling at 700rpms is consuming about 1.5 gallons per hour. Not very much, so even that little fuel filter can take several minutes to run.
CigDaze is offline
towhead
03-26-2008 05:36 PM
Strip Poker 388
09-17-2004 08:02 PM
Jolley
05-14-2003 09:47 PM
SpeedGirl
05-12-2002 11:24 PM
puder
02-13-2002 01:00 AM
