Go Back  Offshoreonly.com > Technical > Detailing, Painting, & Fiberglass
type of paint and clear coat for marine airbrushing >
Old 11-13-2007 | 11:02 PM
Default type of paint and clear coat for marine airbrushing
Having some graphics airbrushed on my boat.... Anyone have a prefrence on brand and typr of paint for this application..
Zookeeper266 is offline
Old 11-14-2007 | 06:26 AM
rchevelle71's Avatar
I used one shot sign paint, and Urethane automotive clear.
Attached Thumbnails type of paint and clear coat for marine airbrushing-pan3.jpg
rchevelle71 is offline
Old 11-14-2007 | 08:58 AM
one shot does last along time, clearing it even better.
excalibur32 is offline
Old 11-16-2007 | 09:30 AM
glassdave's Avatar
Neno the mind boggler
Depends on what kind of graphics you are doing. I use PPG's DBC basecoat with DCU 2021 for a clear. If its a simple highlight or name on the back of the boat OneShot is ok but anything larger than a few square feet i would step into an automotive system. Way easier to work with, less film build and faster tape times. What kind of graphics are you adding?
08 OPA High Points Champion
glassdave is offline
Old 11-16-2007 | 06:07 PM
Jungle grapics down the side of my boat. I appreciate your input on this...
Old 11-16-2007 | 08:04 PM
Glassdave is correct on this, anything big, and especially with fades, you wanna use DBC, and 2021. I have painted many cars with that system, and it is very durable and easy to mix and use, very forgiving also. The other advantage to DBC is you can get it custom mixed any shade of any color ya want, or if ya see some color on a car that you would like to use, its easy enough to get the code, and just have it made.
Old 11-18-2007 | 11:10 AM
glassdave's Avatar
good point on the fades rc, thats right they are tough (almost impossible) with oneshot. The good thing about using an automotive basecoat system is very little film build and very fast dry times when doing multiple layouts. also fast coverage and easy repairability. If you do intend to do some fades you will also need to get some DBC500. Its a clear basecoat that allows you to extend open times and helps give a cleaner tape edge on overlays
Old 09-19-2013 | 08:43 PM
Are you still there? about the paint, if I use the PPG's DBC basecoat, Can I use Fibre Glass 180 crystal clear gel coat over it instead of the 2021
Sir Richard is offline
Old 09-19-2013 | 08:44 PM
I want to paint the entire boat, do spider graphics on the side and bow and then clear coat.
Old 09-19-2013 | 08:50 PM
Why would you use that???? Doesn't make sense. Just clear the boat with 2021.
POWERPLAY J is offline
