I go. Drive stand/remover
Old 11-18-2007 | 07:17 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default I go. Drive stand/remover
Made by making a couple of adapters for my engine stand.
The height is fully adjustable with approx 10" swing, for a total of 20" height range. No need to jack the trailer tongue up or down to match a stationary type of stand. Simply rotate the head to the desired height to match the installed drive height, tighten lock bolts. The drive is held on the mount by sliding the long trim ram cyl rod thru, and slipping the 2 steering ram bolts in. No need for nuts, the weight of the drive keeps it all in place. Once the drive is removed, it can be rotated a full 360* if desired. Can also unbolt the mount from the large angle plate and bolt it to a work bench if desired also. I made this for use with my Lathem drive cap, so limited on application w/o modifying the mount. But that's easliy done when the time comes.
US1 Fountain is offline
Old 11-18-2007 | 08:01 PM
thunderusone's Avatar
That Kicks AZZ!!
thunderusone is offline
Old 11-19-2007 | 12:41 PM
Panther's Avatar
Frank's Marine Service
Very cool!
Panther is offline
Old 11-19-2007 | 12:47 PM
Very kool ,now thats using your noodle
Old 11-19-2007 | 02:23 PM
Straight forward!!! You are what makes America great.
excalibur32 is offline
Old 12-11-2007 | 02:11 PM
NoQuarter
Yes, very cool. Love the rotate to desired height. Brilliant!
Old 12-11-2007 | 05:00 PM
Ginger or Mary Ann?
Thanks guys.
(head swelling up)
Old 01-03-2008 | 10:09 PM
Gizmo's Avatar
Are we having fun, yet?
Take a look in the Q&A section of the technical forum. Klaw had another thread about quick and easy drive remover/installer/stands. There are several styles to choose from including one that I built. I put the measurements for mine on that thread, with pictures.
Jay
Gizmo is offline
waconda
Do It Yourself, Boating on a Budget
10
10-23-2008 08:45 PM
cloudmaster_321
Drives and Lower Units
6
05-23-2008 09:12 AM
Bilgerat
0
04-02-2007 09:24 AM
Roger 1
06-03-2006 12:16 PM
Krumbsnatcher
39
11-17-2003 09:47 AM
