HELP! lost locks to remove bravo drive suggestions? >
Old 11-18-2007 | 08:01 PM
Default HELP! lost locks to remove bravo drive suggestions?
Can anyone suggest how to remove a lock on a Bravo Drive, not prop lock but where drive bolts to gimbal.
Thanks for the help
bonecrusher is offline
Old 11-18-2007 | 08:06 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
I've used a dremel with a cut off wheel to cut thru the surround 180* on the McGards brand, then used a screw driver to split it away from the 'nut'. Once the surround was off, vice grips or a socket pounded over the nut will remove the nut. Probably took less than 5 min to remove.
US1 Fountain is offline
Old 11-18-2007 | 08:11 PM
Thank you for the advise!! next time I will odrer a extra key
Old 11-18-2007 | 08:13 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Is it a McGard? This happens more than you think. McGard may be able to send you a key if you can draw the lock accurately. Better bet is to contact a local large marina. They usually have a plethora of keys.
Sydwayz is offline
Old 11-18-2007 | 08:47 PM
A boat I just bought this year had one, and of course the seller did not have a key. I am sure the drive had never come off, and it was seven years old.
The guy who did my winterization just said no problem. Had it off in a jiffy. And, he did not have a key that fit. Makes me wonder just how much protection these things offer. I'm guessing 5 minutes. Only good for very public places I guess.
A dark corner, forget about it. They want it, they will get it.
Fast Algae is offline
Old 11-18-2007 | 08:54 PM
packinair's Avatar
No Comment
From: This post copyright, Packinair Inc. All rights reserved.
try this
http://kitsapsun.com/news/2007/nov/1...oosen-lug-nut/
packinair is offline
Old 11-18-2007 | 08:55 PM
outriggers's Avatar
I remember my dad saying , locks are for honest people. Doug
outriggers is offline
Old 11-18-2007 | 08:58 PM
Ginger or Mary Ann?
I figure my McGard locks are a little bit of a deterant for the criminals that don't know better. See a lock, move on to next boat.
Plus if my drives were to get stolen, I have pics showing the drives wiht the locks, and prop locks, installed. Might help with Ins. showing I did take precautions.
Old 11-18-2007 | 09:00 PM
Outdrive1's Avatar
Masher touches my
I've done it too, those pieces that surround the lock will just break off once you cut a relief in the side. Takes about 5 min like you said.
Outdrive1 is offline
Old 11-18-2007 | 10:02 PM
Thanks I knew I could count on my OSO friends. Much thanks!
