Discolored CMI Headers
Old 11-23-2007 | 04:21 PM
Default Discolored CMI Headers
What are you guys using to remove the discoloration. Sort of a brownish/blue color. Any suggestions would be greatly appriciated.
raytart is offline
Old 11-23-2007 | 04:23 PM
lucky strike's Avatar
Buy the stuff called on & off at any parts place. Spray it on a rag, wipe the rag on the header, and off comes the discoloration.
lucky strike is offline
Old 11-23-2007 | 04:29 PM
Wow, That was easy. Thanks
I'll see if if can find it somewhere.
raytart is offline
Old 11-23-2007 | 06:08 PM
Elite Marine's Avatar
Any of the metal polishes should take it right off. the bigger issue is what caused it? You should have adequate water flow to keep the out jacket cool.
I would check to make sure you dont have any water issues, as this is not typical or good.
If I can help in any way other than buffing your headers , let me know.
Kirk
Elite Marine is offline
Old 11-23-2007 | 07:55 PM
The only place mine ever get any color change is right at the head., and that is very slight.
Griff is offline
Old 11-23-2007 | 09:03 PM
el indio's Avatar
too much heat..............
el indio is offline
Old 11-23-2007 | 11:19 PM
Polish called "Rolite" Its the best ever. Look it up on the net and order some. It has many uses plastics, metals, etc. Its awesome
ILMORdude is offline
Old 11-24-2007 | 05:44 AM
Vinny P's Avatar
I hate the winter!!
This season, I had a water flow issue. It caused 1 header to turn brown/blue in a matter of seconds. As was mentioned, On/Off took the majority of the discoloration off. The rest was polished off with a good metal polish. The header looks like new again.
Vinny P is offline
Old 11-25-2007 | 10:38 AM
Thanks for the input. I don't believe I have any water flow issues although I did get hot oncce due to sucking mud in. The discoloration is only on one side and down low close to the base of the header. It hasn't gotten any worse over time. I'll clean it and keep an eye on it.
raytart is offline
Old 11-25-2007 | 11:16 AM
Registered User
If your water-jacketed headers are turning blue, you have water flow issues. If your tubes are turning blue, your heads are getting cooked as well- maybe even the lower end. It doesn't take much overheating to crack a head between the seats or drop a seat out. A pressure check on the heads now may save you a complete motor replacement later.
Everyone should have a water pressure gauge with the sender mounted in the intake crossover. That's the only way to know if your engine is getting coolant.
Chris Sunkin is offline
