Otboard engines......
Old 11-24-2007 | 05:50 PM
Magnum25's Avatar
Red face Otboard engines......
This my be a stupid question but here it goes.....do outboard engines need to be winterized?
Magnum25 is offline
Old 11-24-2007 | 06:32 PM
Gladhe8er's Avatar
Yes. 2 and 4 strokes should be winterized/fogged.
Gladhe8er is offline
Old 11-24-2007 | 06:46 PM
Brad Zastrow's Avatar
A lot of people do nothing. However, outboards self drain the water everytime you pull out of the water. I fog the engine through the intake if possible or pull the plugs and spray into the cylinders and roll the engine without starting it. Also to make sure all the water is out of the block I would tilt the engine down for a few minutes. Change the lower unit oil.
Brad Zastrow is offline
Old 11-24-2007 | 06:51 PM
Enforcer2's Avatar
From: Ocean Pines, Maryland. Wish I was at MANGOS in MIAMI!
I use my boat year round (when I'm not building another) so I generally don't winterize my boat until the water is frozen and I cannot get the boat off of the lift!!
Then I fog the outboards to coat the cylinder walls and also stabilize the fuel. Usually Late December or early February to April.
Don't know if this would apply to four strokes or if they hold any water in the block or other parts. I have never had any problems with 2 strokes.
2 Strokes of course
Enforcer2 is offline
Old 11-24-2007 | 08:46 PM
TeamSaris's Avatar
Driver-441
Racer
Yes.Fog em......
Dumbazz
j/kJust bustin on ya bro
TeamSaris is offline
Old 11-24-2007 | 10:00 PM
rush's Avatar
Just trim the engin down, turn the key off and walk away, its that easy.
rush is offline
Old 11-24-2007 | 11:57 PM
Magnum25's Avatar
Originally Posted by fast fun 2
Yes.Fog em......
Dumbazz
Magnum25 is offline
Old 11-24-2007 | 11:58 PM
Magnum25's Avatar
Thanks for the responses guys
Magnum25 is offline
Old 11-25-2007 | 09:17 AM
TeamSaris's Avatar
Driver-441
Racer
LubeJobs42
02-29-2008 10:38 AM
docmanrich37
03-16-2006 08:19 PM
thedonz
12-16-2003 02:32 AM
fishead
Mid Atlantic US
9
12-28-2002 09:25 PM
