arneson asd7m surface drive vs bravo xr >
Old 11-25-2007 | 11:49 PM
Default arneson asd7m surface drive vs bravo xr
OK, I need some info on surface drives. I am hoping to change out the drives this winter. I currently have a 35' Nordic Flame, twin 525's with xr drives. I was looking at IMCOs, but then started to think about surface drives.
What are the advantages, and dis advantages of surface drives? Has anyone done a similar application? How does it effect handleing? How does it compare price wise?
All information appreciated
beertruck is offline
Old 11-26-2007 | 06:12 AM
TeamSaris's Avatar
Driver-441
Racer
They work well on some boats and not as well on others.Do a search on the topic
TeamSaris is offline
Old 11-26-2007 | 07:04 AM
Canada Jeff's Avatar
Are you looking for more speed? Your XR's should be strong enough for your power.
Canada Jeff is offline
Old 11-26-2007 | 09:16 AM
Ask Rik Wimp at Arneson, they will not break and cheaper than you think.
excalibur32 is offline
Old 11-26-2007 | 10:46 AM
would not mind more speed, would love more stability at speed, hoping the nose cone on the IMCO, 2" shorter for both the above.
I have already blown one drive, at 75 hours, and want something more bullit proof, to ensure less down time, and $$$
Old 11-26-2007 | 11:06 AM
Than the Arnison is your answer. Report back with your findings please.
Old 11-26-2007 | 11:20 AM
Wobble's Avatar
SORE MEMBER
Have you considered Konrad drives?. I know I would give them serious consideration based on the feedback I have read here.
Wobble is offline
Old 11-26-2007 | 12:39 PM
what are the handling charactoristics of the arnesons vs the bravos?
Do they help high speed stability (80-92 mph)
how are they coming to plain?
docking?
assume they are fairly bullit proof for moderate hp (525-750 hp)
anyone on the board that you know of that has used it on a 32-40' stepped hull v boat?
thanks
Old 11-26-2007 | 12:43 PM
throttleup's Avatar
You may not be able to acheive the bow lift you need on that boat. You need to approach this with EXTREME CAUTION!
throttleup is offline
Old 11-26-2007 | 12:52 PM
current set up had a problem with too much bow lift. I have removed two of the four batteries from the back, and have the drives slightly toed in to keep the nose down at speed. I had Tres Marten look at the boat a couple years ago, during a driving class, and he seemed to think the center of gravity was off in the boat, too much weight in the back.
