454 vs 502 flywheel >
454 vs 502 flywheel
454 vs 502 flywheel
Old 11-27-2007 | 09:09 AM
ls1nova's Avatar
Default 454 vs 502 flywheel
Is there any difference between the 454 mark IV flywheel and the 502 gen 6 flywheel? As far as I know the 454 and 502 flywheels are the same, but I'm not sure if they interchange between the mark IV and gen 6. I know they bolt up, but is the balancing aspect of it the same?
Thanks,
Frank
ls1nova is offline
Old 11-27-2007 | 11:34 AM
Was the 454 a Mag? If it wasn't then no the flywheels cannot be interchanged.
ThruHull is offline
Old 11-27-2007 | 11:38 AM
ls1nova's Avatar
Yes 454 Mag with steel crank.
ls1nova is offline
Old 11-27-2007 | 12:42 PM
Just because its a mag make no difference at all. Yes a MarkIV 454 and 502 are interchangeable.
The Mark IV is a two piece seal and the gen 6 is a one piece.
I just made the mistake when I bought a gen 6flywheel for a MarkIV. I ended up throwing it in the scrap bucket and I just machined a 400 flywheel for a 454 MarkIV. The counter weights had to milled off.
1BIGJIM is offline
Old 11-27-2007 | 12:50 PM
ls1nova's Avatar
They are both externally balanced right?
ls1nova is offline
Old 11-27-2007 | 01:12 PM
The Mag 454 had forged internals, the non mag 454 had cast internals unless I am wrong. The flywheel off of a 454 with cast internals cannot be used on a 502.
ThruHull is offline
Old 11-27-2007 | 02:22 PM
ls1nova's Avatar
So as long as they are both Mag's with steel cranks, they are interchangable right?
Thanks,
Frank
ls1nova is offline
Old 11-27-2007 | 02:45 PM
I am pretty sure. I will check Dennis Moore's book tonight. He has a couple pages explaining what is interchangebale.
ThruHull is offline
Old 11-27-2007 | 03:11 PM
Steel cranks and cast cranks are the same for Mark IV engines.
Yes they are both be external balance.
The 396, 402 and 427 where internal balanced engines.
I assumed you where going to have the flywheel balanced with the rest of the engine components? Or do you plan to just replace the one you currently have?
I just reread your original post. Are you asking if a Gen 6 flywheel will fit on a MarkIV? If so, NO it will not work without machine work. The had additional weight added when they went to the one piece seal.
Hope this clears things up.
1BIGJIM is offline
Old 11-27-2007 | 07:52 PM
I can't put my hands on my Dennis Moore Book but here is a link I found........
http://www.offshoreonly.com/forums/s...+454+Flywheels
ThruHull is offline
