Windshield fairing for a 32 >
Old 12-04-2007 | 11:03 AM
Registered User
Default Windshield fairing for a 32
I've been looking at pics of other AT's, I see some with a fairing & some without. The 96 32 that I'm working a deal on, does not have one. I noticed, during my ride on "Thunderstruck", that Tom has a fairing & it definetly works. My question is, where can I get a fairing for a 96, or will it have to be custom made?
Just something I was wondering about....
rangerrick63 is offline
Old 12-04-2007 | 12:26 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
You can have it made at a local plastics shop. I'd go for 3/8" thick lexan.
Quick details:
Make a pattern out of cardboard, and then have it made locally. You remove the pad that goes across the front of the top of the dash/very edge of the deck. Screw the lexan in here, and then put the pad back over it.
Sydwayz is offline
Old 12-04-2007 | 01:51 PM
Registered User
Do you think 3" is tall enuff?
How is the pad attached?
Old 12-04-2007 | 02:03 PM
cosmic12's Avatar
There should be 3 or 4 straps (seperate) around the pad, look behind them there should be screws.
cosmic12 is offline
Old 12-04-2007 | 02:23 PM
Mine is 3" tall and works pretty well.
Griff is offline
Old 12-04-2007 | 04:10 PM
Mine is 3" tall that is sticking above the pad you will need it appx 6" or so to put down behind pad and screw it fast , as cosmic said the screws are behind the slip over pads.
rssteiny is offline
Old 12-04-2007 | 04:25 PM
here is a pic of mine it was made at a plastic shop then i drilled and instaled it to fit
rssteiny is offline
Old 12-04-2007 | 05:58 PM
Registered User
Thanks,
I really love that paint job on your boat. I do wish it was within my price range, that's a great looking boat.
Old 12-05-2007 | 06:57 AM
Originally Posted by rangerrick63
Thanks,
Thanks i love it as well, you will love a 32 thunder i gurantee it.
rssteiny is offline
Old 12-05-2007 | 07:51 AM
Default I find mine to be a pain..
Makes it harder to get on the bow of the boat, it looks good but they can make it in more than one piece to have easier bow access. No I am not an old man, but the cockpit is deep so not so easy to go drop an anchor. I have a 28 there is no stair,does the 32 have built in stairs? Vic
risky is offline
