33 Powerplay speeds with 600hp >
Old 12-04-2007 | 07:45 PM
ls1nova's Avatar
Default 33 Powerplay speeds with 600hp
Anyone have any experiance with this hull? I know this hull is not the fastest, but what kind of realistic speeds should I expect to see with a solid 600Hp per side in a 94 33 Powerplay sportdeck? Would my expectations be too high if I was thinking mid to high 80s?
Thanks,
Frank
ls1nova is offline
Old 12-04-2007 | 07:53 PM
Thanks,
Frank
That doesn't sound like a problem. I helped rig a 33 Powerplay a few years ago with twin 502 / 600's and we ran 91 mph on GPS all day long.
mjw930 is offline
Old 12-04-2007 | 08:11 PM
ls1nova's Avatar
Awsome! Do you remember what year that one was?
Thanks,
Frank
ls1nova is offline
Old 12-04-2007 | 08:18 PM
I think it was a '96 but the bottom design through that period was the same so unless it was layed up with a different material any 33 from that era should be very similar.
mjw930 is offline
Old 12-04-2007 | 08:45 PM
Indy's Avatar
Member #154
JROMY has a 33' with the Merc 525s and he gets 87, all stock engines and props.
Indy is offline
Old 12-04-2007 | 10:46 PM
FeverMike's Avatar
Scott Utah's F2 33 Powerplay with HP500's ran around 83mph. Another couple 100hp should put you at 90+ @ WOT. With today prop technology and if the bottom and drives are really good you should do a little better.
FeverMike is offline
Old 12-04-2007 | 11:15 PM
Semper Fi's Avatar
I had a 1997 33' Powerplay race model (3 man bolster) with staggered HP 500's-- she ran around 84mph top speed with 3 blade Mirage's.
I think with 600's you should be in the high 80's- low 90's. I can tell you that it's a BADA$$ hull for sure!
Semper Fi is offline
Old 12-05-2007 | 06:51 AM
Indy's Avatar
Member #154
I know this hull is not the fastest, Thanks,
Frank
Trust me, it's plenty fast when the water kicks up.
Indy is offline
Old 12-05-2007 | 07:24 AM
Charter Member #71
With stock HP500's my 33 ran 80.
WesSmith is offline
Old 12-05-2007 | 03:25 PM
ls1nova's Avatar
Is there any speed difference between the taller post 95 hulls, vs the lower pre 95 hulls? I'm guessing the pre 95's weight less.
Thanks,
Frank
ls1nova is offline
