Wet Spot Filter ?
so... its a tube full of resin beads .. hard water goes in ..soft comes out .... The recharge Tube is empty ... the directions say to fill with water softner salt and back wash ...
hmmmm ... only 800.00 ....
Registered User
Registered User
You can make them your self with some fittings from a hardware store ans a 1/2" pipe tap. You can buy the resin at a softener repair place or on-line. Probably make the whole thing for under $100. I've seen build plans on the net before.
I have a softener on the house and regardless of what type of salt I use we still get calcium spots, that are very hard to remove, even on the glass. Looking at a D.I. water generator(De Ionized) simular to the final rinse used before powder coating.
Registered User
I'd start with looking into why your softener isn't doing the job.
zimm17
3
05-01-2007 01:58 PM
