Mobil synthetic 75/90 gear oil >
Old 12-11-2007 | 05:11 PM
Default Mobil synthetic 75/90 gear oil
Any one using mobil systhetic 75/90 gear oil in there outdrives? Goood, bad, or indifferent.
Mine is a 2004 XR and is in need of an oil change.
Hy-Velocity is offline
Old 12-11-2007 | 06:45 PM
cuda's Avatar
I run it in my Kaama drives, with no problems at all.
cuda is offline
Old 12-11-2007 | 08:14 PM
Thanks Cuda, how often do you change
Old 12-11-2007 | 09:59 PM
monstaaa's Avatar
great stuff. period.
monstaaa is offline
Old 12-12-2007 | 02:48 PM
I use it in a Bravo, works good.
Pismo10 is offline
Old 12-12-2007 | 02:51 PM
Anyone use it in a TRS?
smdude is offline
Old 12-12-2007 | 03:04 PM
I ran it in a overpowered Alpha 1 for around 5 years with no problems. The gears looked great every season after teardown. I changed it every 25-30 hrs. This summer I had a leaky seal and water entered the drive. I noticed the gear oil resevoir off color and pulled the boat and replaced the seals and cleaned everything. Gears looked ok. Put it back together and the next change I noticed alot of metal on the magnet. Tearing down the drive revealed the F and pinion gear teeth were coming apart.
Did the Mobil 1 being diluted with water cause this? Would Merc HP Syn have prevented this? It's up in the air but I am switching back to Merc Syn just b/c of this as it supposedly protects better if water enters the drive.
Ryan00TJ is offline
Old 12-12-2007 | 11:21 PM
Rebel_Heart's Avatar
Always ran the Merc stuff. Changed to Royal Purple 70/90. Probably similiar to Mobil. I plan on changing every 30 hrs.
Rebel_Heart is offline
Old 12-13-2007 | 08:32 AM
I would be reluctant to use anything thats not designed to tolerate water. If it has emulsifiers and the like it will say so.
MOBILEMERCMAN is offline
Old 12-13-2007 | 08:36 AM
Panther's Avatar
Frank's Marine Service
The Amsoil Marine Lube is set up for that. I've been using it for two seasons...so far so good....It's a little "thin" though...
Panther is offline
