Need help
Old 12-14-2007 | 09:14 AM
Default Need help
Hey Banana Heads or better yet Charlie
I am getting ready to start restoring hull # 3 and i have some soft deck issues "insert joke here" I was wondering is the for deck balsa cored or wood also it looks like the soft spot runs the length of the deck and is 10 inches wide was this a seperate piece of fore down the center?
thanks
Josh
oldschoolfan is offline
Old 12-14-2007 | 09:49 AM
Top Banana's Avatar
thanks
Josh
The deck on that boat was balso cored with a strip of marine plywood running down the center for strength.
Take off your deck hatch and it should show you the areas of woood vs balsa.
The areas around the hatch is where the water could get in and start your soft problems after so many years.
Top Banana is offline
Old 12-14-2007 | 03:16 PM
charlie thanks for getting back to me
I have Second Choice no hatch on this boat was the center still ply? The problem started when the saftey line was removed and the holes were never filled
will this boat still have the plywood even though there is no hatch
josh
Old 12-14-2007 | 07:39 PM
Top Banana's Avatar
josh
Yes...they were built with that plywood strip for strength on the inside...... to do what the 28SS Cigarette had that strip on the outside to do.
You can see the raised deck on the 28 compared to the flat deck on the 24 right next to it.
Old 12-15-2007 | 08:05 AM
Charlie
would you suggest cutting the deck and working from above or working from underneath
Josh
Old 12-15-2007 | 09:10 AM
Top Banana's Avatar
Charlie
Josh
Underneath....don't disturb that glass on top if you don't have to.
