Trailer security?
What security devices are you guys using? I got a Master lock coupler lock when not hooked to truck. Also was thinking about a boot/wheel lock for when parked at ramp area like this one http://cgi.ebay.com/ebaymotors/ws/eB...192157819&rd=1
Of course I use hitch lock pins. Anything else you have found?
Offshoreonly Advertiser
Registered User
4 Kryptonite Fahgeddaboutit chains thru the wheels and a Trimax tongue lock. http://trimaxlocks.com/FullSize/UMAX100.htm
You'll need a torch or a abrasive cutoff saw. Or a crane.
At home it's inside.
If they want it bad enough they'll get it. Locks & chains are deterrents to amateurs and crimes of opportunity.
We had our enclosed motorcycle trailer stolen with a coupler lock and a pin lock on it. There was no evidence that either had been cut off. We think they rolled it up onto a tow truck type tilt trailer or tied it to a trailer hitch/ball and just drove it far enough away to cut the locks off. At least we had taken the Harleys out or they would have been gone too. This happened in a busy apartment parking lot. I think the boot/wheel lock or even running a good quality chain/cable lock thru the wheels would help. Anything to keep them from moving it. I would keep the other locks on, too, just to make it difficult.
http://www.amazon.com/DeWalt-MobileL.../dp/B000IZG9VG
I do realize that but I feel anything you can do to slow them down or make it so much trouble that they move along is worth it. Anyone use one of those boots? Are they easily defeated?
Registered User
The issue with the boots is dragging them along. I wanted more than one and carrying four of them would be cumbersome. The four chain setups fit right in a small box on the trailer. It takes just a minute or two for each one- it goes through the front and middle wheel and locks, then another through the middle and rear. The only way to defeat them is to cut. The boot locks look susceptible to slide-hammering the lock and/or freeze-fracturing it.
Selling trailer security devices, I have seen the good, bad n ugly.. At best you are going to slow them down, you are not going to stop them. Bootlocks like the trimax are not bad, but rarely work with trailer brakes. They are defeatable, and rather easily. The stern lock one is interesting, but I need to see it before I would feel comfortable commenting upon it.
The chain theory is dependent upon your locks. I ONLY sell Abloy and Cisa chain locks, and only use them myself. With these locks the chain becomes the weak point, not the lock. That said, I can also SILENTLY cut hardened square link chain in 4 seconds with a commonly available tool... No, I won't tell ya what it is either...
Met a guy at a local 7-11 a month ago who thought he had it all figured out. Locked the trailer to the truck, locked the boat to the trailer and locked the truck. Mistake was they stole the whole rig! Truck, trailer and boat!
