In need of Bravo 1 Caps for external Steering!!! HELP!!! >
Old 12-16-2007 | 07:03 PM
Registered User
Question In need of Bravo 1 Caps for external Steering!!! HELP!!!
Hello Everybody!!
I just purchased hydraulic steering from a OSO member but seems I need one more piece. I need the Cap that the actaully plates bolt up to on the drive. Check out my pics to see what I am talking about....They are ZEIGER steering. In need of Bravo 1 Caps for external Steering!!! HELP!!!-sonic-drive.jpg
Powerboat713 is offline
Old 12-16-2007 | 07:11 PM
PhantomChaos's Avatar
That is a drive shower...an after-market item. It has noting to do with steering....supposedly keeps the drive cooler.
PhantomChaos is offline
Old 12-16-2007 | 07:33 PM
Registered User
I know that, I need the BRAVO END CAP that replaces the upper drive shaft housing so the external steering brackets can hook up to the drive.
Old 12-16-2007 | 08:29 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
IMCO makes end caps that for hydraulic steering attachment. They may have something that will work for you.
Sydwayz is offline
Old 12-16-2007 | 08:43 PM
I will check in the morning Powerboat , i believe i have 1 still in the box on the spare parts shelf. Does it look like these ???
Attached Thumbnails In need of Bravo 1 Caps for external Steering!!! HELP!!!-picture-002.jpg
Old 12-16-2007 | 09:00 PM
I'm sure you could use a different end cap like the Imco posted by RH or a different company's bracket. If you want it to be a matched Zeiger cap then I found this site.
http://www.everettperformance.com/
Also, Dana Marine sells Zeiger steering.
Griff is online now
Old 12-17-2007 | 06:59 AM
we have a pair of used latham's.give a call if that helps.
954-237-0332 Doller Offshore
dollerparts is offline
Old 12-17-2007 | 07:14 AM
Hey POWERBOAT are you lookin for 1 or 2 ??? L@@ks like Mindy at Dollar got you covered ..We've had nothing but good dealings with them
ROCK ON & Happy Holidays
Old 12-17-2007 | 07:16 AM
Canada Jeff's Avatar
I hope your thread doesn't get moved, I ask for a 496 block, and it was moved.
Canada Jeff is offline
Old 12-18-2007 | 11:05 AM
Registered User
Yeah, thats what it looks like RUNNINGHOTRACING
