How do I get a prop lock off iff I dont have the key?? >
Old 12-22-2007 | 09:49 PM
rchevelle71's Avatar
Default How do I get a prop lock off iff I dont have the key??
I picked up my new(used) outboard today, and I went to take off the old prop, and install mine, but the damn thing has what looks like a wheel lock holding it on insead of the nut. I will call the shop that sold the motor to me on monday, but I dont think they will have it. Any Ideas???
rchevelle71 is offline
Old 12-22-2007 | 11:12 PM
Strip Poker 388's Avatar
Rob
Originally Posted by rchevelle71
I picked up my new(used) outboard today, and I went to take off the old prop, and install mine, but the damn thing has what looks like a wheel lock holding it on instead of the nut. I will call the shop that sold the motor to me on Monday, but I don't think they will have it. Any Ideas???
Its not hard, I am having problems with the Mcguard locks/nuts loosing, If I don't keep an eye on it I would loose a prop.
http://www.offshoreonly.com/forums/s...ghlight=mcgard
Strip Poker 388 is offline
Old 12-23-2007 | 06:43 AM
Fountain38SC's Avatar
die grinder took mine off. just cut the outer case and remove the nut.
Fountain38SC is offline
Old 12-23-2007 | 08:51 AM
I've heard you can get them off by using 2 screw drivers and then a wrench or tool to turn the screw drivers. You insert the screw drivers down inside the lock. Then use the wrench / tool to turn the screw drivers to remove the lock. Good luck.
THLWL is offline
Old 12-23-2007 | 09:35 AM
CMC
Go to sears and buy the sockets that are used for removing rounded off nuts. These sockets grab into the nut and then come off as normal. I used them to get the lug nuts off a corvette when the previous owner had no idea where the key was.
CMC is offline
Old 12-23-2007 | 01:14 PM
Sears Bolt-Outs #52160
JimmyBaja is offline
Old 12-23-2007 | 02:01 PM
jam a smaller socket on it and then turn it.....
lowblue320 is offline
Old 12-23-2007 | 03:45 PM
Cat & Mice's Avatar
You can draw a picture of the pattern and fax it to Mcguard and they will sell you a new key. They only have about 4 or 5 keys.
Good luck!
MP
Cat & Mice is offline
Old 12-23-2007 | 06:54 PM
well, it wasnt as easy as a wheel lock.
good product, took me about 3 hours, and 7 dremel cutting wheels to cut off the ring around it, then I could jam the socket on, and get it off, all without scratching the prop.
Anyone need a 17 mirage??
Old 12-23-2007 | 08:46 PM
Rob
The way I did mine didnt take 30 min
