Help with trim motors
I need some help. Recently.. my old Formula starboard outdrive trim just stopped working, like if there is no power to it. I checked, power is OK, can it be the switch? some safe guard in the unit? Port is OK. (1985 Merc system.)
THx .. P
THx .. P
When you push the switch do you hear a click back there? You may need a second hand to look for power getting to the relay side of the switch (smaller wires). Do you have a trailer switch? could be a issue with that as well. Does it work in one direction and not the ohter? If so then check the fuse that is ussually located back at the pump.
Jon
Jon
Put your best foot forward!
Do you have circuit breakers under the rear seat like the 311? That's where my trim power comes from.
