Wanted: 3 Blade 23P Mirages >
Old 12-24-2007 | 04:51 PM
Default Wanted: 3 Blade 23P Mirages
We're looking to try a pair of 3 blade 23p Mirage props for TRS Drives. Anyone have a pair? Thanks in advance.
Lucky Strike Jr is offline
Old 12-25-2007 | 12:02 AM
rchevelle71's Avatar
Steve, I have a pair that you are welcome to try.
Rick
rchevelle71 is offline
Old 12-25-2007 | 12:04 AM
Oh yeah, they are solid hub, and mey need different thrust washers, give me a call, and we can check it out, 954-254-0414.
Rick
Old 12-25-2007 | 02:12 PM
http://cgi.ebay.com/ebaymotors/PAIR-23-PITCH-MIRAGE-PROPS-STOCK-17-18_W0QQcmdZViewItemQQ_trksidZp1638Q2em118QQcategor yZ26456QQihZ013QQitemZ230203787046QQrdZ1QQsspagena meZWD1V
this is speed and custom marine , i think there by you guys and probably would cut you a better price than the ebay price , that's if rchevelle71 needs to keep his.
open87 is offline
Old 12-25-2007 | 03:15 PM
lucky strike's Avatar
Thanks guys.
What is the difference between the Mirage plus & Mirage ?
lucky strike is offline
Old 12-27-2007 | 11:49 AM
BY U BOY's Avatar
Originally Posted by lucky strike
Thanks guys.
The plus has more cup in it.
BY U BOY is offline
Old 12-27-2007 | 12:35 PM
Is TRS shaft same as Bravos? If they're still there, should be in our backyard somewhere:
http://fortlauderdale.craigslist.org/boa/515307409.html
handfulz28 is offline
Old 01-27-2008 | 05:14 PM
POOL WHORE's Avatar
Digging through the garage revealed a boxed up set of 23P Mirage props with a solid hub. Steve, do you still need them? Anyone?
Hugh
Attached Thumbnails Wanted: 3 Blade 23P Mirages-mercury-3-blades-001.jpg   Wanted: 3 Blade 23P Mirages-mercury-3-blades-002.jpg   Wanted: 3 Blade 23P Mirages-mercury-3-blades-003.jpg
POOL WHORE is offline
Old 01-27-2008 | 05:20 PM
Hugh,I still have your 27 3 blades safe at work!I can bring them to you this week if you want!
JJONES is offline
Old 01-27-2008 | 06:01 PM
POOL WHORE's Avatar
Thanks, man! I almost forgot about those guys. I may be working down South in Coto this week and can stop by the dealership.
Hugh
