whats the deal with this boat? >
Old 12-25-2007 | 01:51 PM
Default whats the deal with this boat?
http://cgi.ebay.com/ebaymotors/33-Tu...QQcmdZViewItem
reliable setup?
who did the transformation?
whats the deal with the trolling motors on the kplanes?
Perlmudder is offline
Old 12-25-2007 | 04:57 PM
Sea-Dated's Avatar
Trolling motors on each K-Plane and one on each side of the drive. I guess the 4 electric motors are for docking or manuevering in close quarters.
Or, they have a lot of problems with the turbine and need a way to get back to the dock when it dies.
Sea-Dated is offline
Old 12-26-2007 | 07:34 AM
Dont know the boat, some have even used a small out board. When rafting or just needing to make a small move it is alot harder to spool up than to start a big block and then just turn it off
CLIMAX is offline
Old 12-26-2007 | 12:09 PM
fabricator's Avatar
What's with the name? I don't get it.
fabricator is offline
Old 12-26-2007 | 04:50 PM
I would say since the boat is in South Louisiana...that Marine Turbine Technologies probably did the conversion. Turbines are reliable if you can carry enough fuel. The electric motors are more than likely for reverse.
Will
SC404COUPE is offline
Old 12-27-2007 | 09:38 AM
rjr
It's probably a worn out helicopter motor. Incredibly expensive to overhaul. I'm guessing thats why it's in a boat and not an airplane
rjr is offline
Old 12-27-2007 | 09:53 AM
So what is the range on a boat like that at a cruise speed?
Baja_man is offline
Old 12-27-2007 | 12:16 PM
I understand that they can be very reliable and last A LOT longer than a gasoline or diesel engine. Kind of like commercial aiplanes made in the 70's still in use today.
TexomaPowerboater is offline
Old 12-27-2007 | 01:04 PM
masher44's Avatar
Stupid single engine owner ....
all you need is an oar and a stupid friend on the boat with you.
masher44 is offline
Old 12-27-2007 | 02:42 PM
rjr
All the jets from the 70's have been repowered. Efficiency and noise pretty much required it
Fuel burn? An F-4 Phantom could cary 2200 gallons of gas (internal & an external centerline tank) and under the most economical conditions it would last a little over 2 hours. Jets lose efficiency at low altitudes so a turbine engine at sea level would not be very efficient.
Sea Land had turbine engines in their ships. I understand they sold them to the Navy during the first gas crisis in the 70's
rjr is offline
