gen 5 or 6
Old 01-01-2008 | 06:34 PM
bcfountain's Avatar
Registered User
Default gen 5 or 6
took the engine apart today,502mag,mpi,1994.do i have a gen5,or6?my other boat has a 454,gen4,1989.in taking apart the 502 today i noticed that the rocker stud is diffrent from the 454.the 502 is a bolt.and the 454 is a stud.will the older style stud fit the 502?and will rocker arms interchange.i have a nice set of harland/sharp alumium rockers.they came off my 454 w/only 20 hrs on them.will they fit the 502?thanks.
bcfountain is offline
Old 01-01-2008 | 06:51 PM
The Gen VI 502 Magnum started in the 1996 Model year for mercruiser anyway. Serial # OF802600 and up. So it's a Gen V.
Pismo10 is offline
Old 01-01-2008 | 08:04 PM
ROB FREEMAN's Avatar
gen 5 has a 10 bolt pattern timng cover as the gen 6 will only have 6 easy way to check the two as all three generations have differant timming covers hope this will help
ROB FREEMAN is offline
Old 01-01-2008 | 09:04 PM
the bolt set up is the non adjustable [ net lash type ] you can replace them with the adjustable studs and use your rockers
awesomecat26 is offline
Old 01-02-2008 | 01:01 AM
I don't think the same studs will work. if I remeber right, the MK 4 heads use a 7/16 coarse bottom thread, 7/16 top thread.
The Gen V heads use a 3/8 bottom and 7/16 top. You just need to get the studs with a 3/8 bottom and 7/16 top to use your rockers. These are what you need.
http://store.summitracing.com/partde...5&autoview=sku
Griff is offline
Old 01-02-2008 | 07:03 PM
bcfountain's Avatar
Registered User
Default gen5
thanks guys for all the help.it is a gen510 bolts on the timming chain cover.and thanks griff about the studs.you are right.anybody know when gm started putting roller cam shafts in the 502,s.mine is a flat tapplet,hyd.also,do you think there will be any h/p gains if i switched to roller rockers.thanks.
Old 01-02-2008 | 07:29 PM
Gen VI started the roller cam in Mercruisers anyway.
Pismo10 is offline
GNJ
3
05-23-2007 12:15 PM
superiormgmtco
5
01-29-2007 05:31 PM
klmken
3
04-26-2005 04:30 PM
QUIKDECISION
2
04-25-2005 09:20 PM
Valley Boy
0
03-28-2002 12:52 PM
