Source for hinges and latches? >
Old 01-07-2008 | 02:09 PM
Default Source for hinges and latches?
[B]I am making a storage area on my boat similar to a glove box. I am looking for some hinges that will not be seen from the outside. Also a push button, pull or latch to open and close it with. I have checked West Marine, Rex Marine , and Overtons catalogs, as well as local hardwre stores but don't see what I'm looking for. Anyoone know of a good source for this type of hardware.[/B
Steve
Revd Up is offline
Old 01-07-2008 | 02:14 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
(Trick) sold R'Addiction a nice billet door some time ago. It probably came from Dana Marine, or some place similar.
I don't think that I have seen anything quite like what you are looking for.
Sydwayz is offline
Old 01-07-2008 | 02:28 PM
I would like the hinge to fasten to the inside of the compartment door so you dont see it from the outside. I think it would be like a kitchen cabinet hinges where you don't see the hinge.
Revd Up is offline
Old 01-07-2008 | 02:38 PM
Registered User
http://www.sea-dog.com/Catalog/maincatalog.html
Check the Cabinet Hardware link.
These guys are the OEM on alot of manufacturer's hardware.
Chris Sunkin is offline
Old 01-07-2008 | 05:35 PM
bouyhunter's Avatar
You can always do some shopping at MacMaster-Carr.
www.mcmaster.com
I've found all kinds of useful stuff there.
Everything ships overnight, you'll have it the next day.
bouyhunter is offline
Old 01-07-2008 | 06:00 PM
'05 Concept SF23
You might try Acon Marine in FL. They make more than cleats.
f311fr1 is offline
Old 01-07-2008 | 06:04 PM
CPPerformance's Avatar
Perko and Sea Dog Line seem to have the most options for what you are looking for. I will search around in some catalogs that I have and see what I can come up with and PM you. We can special order any of these type of items for you with no problems.
Brad
CPPerformance is offline
Old 01-07-2008 | 06:12 PM
Steve_H
http://www.hardwaresource.com/Store_...ts.asp?Cat=903
http://www.sugatsune.com/products/Pr...=9&PRODUCTID=R
http://www.southco.com/
Old 01-08-2008 | 11:08 PM
Some great sources here.
Thank you!
Revd Up is offline
Old 01-09-2008 | 06:51 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
http://www.danamarineproducts.com/Gr...TOKEN=69697370
http://www.eddiemarine.com/store/car...uct_list&c=129
Sydwayz is offline
