hatch / plexyglass how to paint
want to change cuddy hatch from smoke plexyglass to white can i paint / will it last and not bubble or peel off . lonlasting and final outcome are a must on this or ill just buy new thanks rob . i dont want a cob job on this . if its not 100 percent doable ill abourt and just suck it up and buy a white one thanks rob
Hi use a adhesive promoter and you will be fine. you can purchase from your local auto paint store. Personally I use PPG but all paint manufactures should carry their own adhesive promoter. You just put it in a paint gun and spray it on. Holla!
Did the same to mine. I use dupont products with great success. But everyone has "they're line" of adhesion promotor / primer.
Depending on the thickness of the plexi you may want to add flex agent to the paint also. Good luck.
SLINGSHOT
Detailing, Painting, & Fiberglass
8
09-06-2011 08:10 AM
