Steel sheet piling / sea wall repair >
Old 01-17-2008 | 06:47 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Default Steel sheet piling / sea wall repair
We lost our steel sheet piling as a result of high river flows, low Lake Michigan water level, a very quick thaw with temps in the 60s, and a snow melt.
Had 16' steel sheet, and now the river bottom is below that and the sheet has slipped. It needs to be replaced with 30' long 7 gage steel sheet piling.
Can anybody provide a very rough ballpark range a job such as this should cost?
Scope:
Furnish sheet, equipment, labor, permits, hardware, etc to :
a. remove destroyed sidewalk cap
b. remove 3 40' fiberglass finger piers from damaged seawall
c. remove 123 lineal feet of bent up and broken 7 gage 16 sheet piling
d.prepare tie bars, etc for new sheet piling
e. drive new steel sheet piling
f. replace finger piers
Concrete sidwalks, electric, plumbing by others.
Just looking for a range - trying to keep the contractors honest.
Thanks for your time
Fred
waybomb is offline
Old 01-17-2008 | 07:29 PM
Was the original sheeting driven from land or from a crane on a barge?
I can give a ballpark on what it would go for in LA. I am not sure what the market prices are up there.
Steel sheeting costs are through the roof. I priced some for a job and almost had a heart attack.
Mackattack is offline
Old 01-17-2008 | 07:32 PM
waybomb's Avatar
I would guess the original was by land, as there was no building there at the time.
Can you tell me what 123 of 40 ft x 7ga sheet pile costs all by itself as well?
waybomb is offline
Old 01-20-2008 | 11:52 AM
waybomb's Avatar
Anybody?
waybomb is offline
Old 01-20-2008 | 11:56 AM
I just paid $120.00 per foot removal and replace only with 20 foot sheets and cap.
Rich
BOSSMAN is offline
Old 01-20-2008 | 01:16 PM
BUIZILLA's Avatar
instigator
why not synthetic glass??
BUIZILLA is offline
Old 01-20-2008 | 06:49 PM
Nykamp's Avatar
Check with The King Co. here in Holland Mich. or DK Construction also here in Holland, DK stands for Dan King,also Equity Marine Construction out of Grand Haven would probadly be my first call, Dale will take good care of you. Materials Intl. down in atlanta area makes some really nice plastic seawall sheets. I have installed theres before, they are really good to work with, good luck.Steve
Nykamp is offline
Old 01-21-2008 | 12:32 PM
baronmarine's Avatar
waybomb
i just talked to one of my customers who is a piling dist. he told me he sells 40' 7 ga. for $4.80 per sq ft. he also told me 7ga is petty thin for driving.
todd
baronmarine is offline
Old 01-21-2008 | 04:46 PM
Tom A.'s Avatar
Waybomb, you have provided a lot of info but there are still many variables. When i get to work tomorrow I can give you an idea on material and installation costs in Jersey.
7 gage is going to be way to thin for 30' sheets. Also, access via land or water is a big factor. My thought would be to install plastic sheeting. We did that at my father's house when the steel sheets coroded through. (salt water) Could you drive the new sheets in front of the old ones? This would save money and retain some of your property.
Tom A. is offline
Old 01-21-2008 | 05:20 PM
I redid both of my marinas in New jersey with corrugated vinyl. WAY better than steel, and probably around the same price (the labor is the same, and the material costs on a job like this are really not all that great relative to the total cost of the job). Go with vinyl if you can. I am looking to do some repairs to the sea wall in my marina in Connecticut, and if possible I will drive the corrugated vinyl in fromt of the damaged corrugated steel like Tom A. suggested.
I will try to get my cost figures from the job we just completed.
Tom
Total Marine
TGC-32 is offline
