Where can I buy Goodyear oil hose? >
Old 01-25-2008 | 10:24 AM
Default Where can I buy Goodyear oil hose?
The local hose cos only offer Parker and Aeroquip and I think $35 for 6ft of hose is well...getting hosed.
I need 6ft of 5/8" oil cooler hose, no ends or anything.
handfulz28 is offline
Old 01-25-2008 | 10:40 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Did you try Napa?
Sydwayz is offline
Old 01-25-2008 | 10:58 AM
Registered User
There are many types of hose- you'd need the specific stock #. If this is low-pressure hose, an aoto parts store can help you. If you're looking for a specific high-pressure hose, remember only Goodyear fitting will work with Goodyear hose and the ends have to be swaged on with a Goodyear machine.
Chris Sunkin is offline
Old 01-25-2008 | 11:28 AM
No luck at NAPA.
I'm looking for the same stuff that Merc uses just without the ends, and Merc pricing. The high temp rating (150C/300F) is what's making it difficult.
This is supposed to be a budget concious remote oil filter for a truck. It doesn't need fancy hose and fittngs.
Old 01-25-2008 | 11:38 AM
Registered User
A hose distributor should have something. The prices you're talking are HP hose. That stuff is so tough you'd have a hard time getting it over a barb fitting and worm-drive clamps are useless on it. Look for the nearest Parker Hose distributor. You can also try Grainger or Mcmaster-Carr. McMaster.com
Old 12-20-2025 | 04:35 PM
tractor/farm supply places have it for fraction of the cost of marine. they use it for moving water for equipment. same **** but cheaper
CDN20VALVE is offline
Old 12-20-2025 | 05:02 PM
F-2 Speedy's Avatar
17 year old thread..............
F-2 Speedy is online now
Old 12-20-2025 | 06:56 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Maybe he's still looking?
waybomb is offline
Old 12-21-2025 | 08:21 AM
Yeah but we got to revisit "Sunkin's wisdom"........from mini bikes to lawn I-beams to Apaches and oil hoses Sunkin knew it all.
Jupiter Sunsation is offline
Old 12-21-2025 | 09:52 AM
is it an AI bot digging up all these old threads?
boostbros is offline
