Touchup on throttle/gear shifter >
Old 01-25-2008 | 04:56 PM
Default Touchup on throttle/gear shifter
The base plate of my shifter is showing some wear. The black paint is peeling off and I was wondering what I can do to touch it up. I'm not going to replace it just because some paint is peeling off. Wouls some nail polish be the dumbest thing you ever heard of ?????? I apoligize for the ignorance.
Here is a picture to show you what I'm talking about. The grey area underneath the shifter really makes it look bad.
So I've got a nice dash with new gauges and the throttle box is just messing everything up. My trim and tab buttons above the throttles also could use some touch up because the black is starting to grey.
Should I just call a fiberglass or paint for the touch up? And whats a reasonable price?
Attached Thumbnails Touchup on throttle/gear shifter-18918_5-large-.jpg
TexomaPowerboater is offline
Old 01-25-2008 | 05:37 PM
Steve_H
take it apart and paint it or have it chrome plated (expensive) or just have the handles polished. you ccan also wrap the base in vinyl for a different look.
i had my handles chrome plated and the bases wrapped in black carbon fiber. not a good pic but all i have. polishing looks the same as chrome plating. you just have to watch out for water spots.
Attached Thumbnails Touchup on throttle/gear shifter-closeup.jpg
Old 01-25-2008 | 05:42 PM
Steve_H
or have the handles and bases powder coated.
pic of the 28 i used to have.
Old 01-26-2008 | 09:29 PM
Steve_H
took a better picture today.....
Attached Thumbnails Touchup on throttle/gear shifter-1.jpg   Touchup on throttle/gear shifter-2.jpg
Old 01-26-2008 | 09:37 PM
Velocity Vector's Avatar
Crazy Energy
Or you may cover it in a adhesive backed vinyl
Velocity Vector is offline
Old 01-27-2008 | 07:42 AM
powder coat
Griswald is offline
Old 01-27-2008 | 08:40 AM
nocigarette's Avatar
take them out and paint them....
Attached Thumbnails Touchup on throttle/gear shifter-magnum-109.jpg
nocigarette is offline
Old 01-27-2008 | 12:20 PM
Thanks a lot. It definately gives me a good starting point.
You did an awesome job on the dash resto of that bullet. I think I may try and have it powdercoated. Although I'm not quite sure which color to go with. Right now I'm thinking a white base and handles. What are you guys thinking - keep it black with some chrome handles or change it to white. Since one of the needles on the trim tab indicator are broke off I may go ahead and make it white too, or replace it with a white one.
I like what this guy did with the dash on his scarab
Attached Thumbnails Touchup on throttle/gear shifter-0101080103020104042007091609dc45c3a035461f6f0043bb.jpg
Old 01-28-2008 | 03:53 PM
I'm thinking I may go with a black base and red handles.
Was it pretty easy to remove the handles from the throttle and shifter assembly?
Old 01-28-2008 | 04:11 PM
BY U BOY's Avatar
Have it powder coated.
I will be doing the same thing soon.
BY U BOY is offline
