2.30" intake valve/piston clearance >
Old 01-29-2008 | 01:37 PM
Grog's Avatar
Default 2.30" intake valve/piston clearance
All -
I am installing a set of HP500 heads with 2.30" intake valves on a stock Gen VI 502. The old heads had 2.19" intake valves. I am running a stock cam and plan on using .040" head gaskets (Fel Pro 17048, I think)
Would you expect any valve to piston clearance issues???
Grog is offline
Old 01-29-2008 | 01:39 PM
Grog's Avatar
Oh, and while I am here, does anybody have a copy of Dennis Moore's Marine BBC book that they want to sell.....rent.....lend?
Grog is offline
Old 01-29-2008 | 08:28 PM
jdnca1's Avatar
Originally Posted by Grog
All -
You should have more than enough...but its still worth checking.
jdnca1 is offline
Old 01-29-2008 | 11:08 PM
You won't have any issues. Pretty sure the engines use the same pistons. The cam you ar eusing is much smaller as well.
Griff is offline
Old 01-30-2008 | 09:39 AM
Greg, I was pretty sure you would be okay. You sure you don't want to change the cam? I've got two "731 Cranes " on the shelf!
kennyo is offline
Old 01-30-2008 | 09:47 AM
Grog's Avatar
Talking
Stop that. Stop that right now!
Grog is offline
Old 01-30-2008 | 04:03 PM
Those heads will work best with 2.250 int. dia. with the correct port work. If your already committed to the 2.300 you will still have to do pocket porting to benefit from the larger valve.
mrhorsepower1 is offline
Old 01-30-2008 | 09:50 PM
Grog's Avatar
I appreciate everyone's input. I realize that I may not be optimized, but right now, my goal is to just get back on the water.......this spring.........without spending more money.
Kennyo - If you still have those 731s next fall, I may be interested in one.
Griff - Why would the cam matter? At TDC of the stroke the lifter should not be on the ramp of the camshaft, and the intake valve should be completely closed...right?
Still looking for, and counting votes. Will I have a problem when I bolt things back together and turn the key?
Thanks again.
Grog is offline
Old 01-31-2008 | 03:31 AM
Thanks again.
Correct, but valve to piston clearance problems really don't happen at TDC, they happen when the cam and piston are moving. A bigger cam will open the valves farther during this process and they will get closer together as they move up and down. The distance also changes if you advance or retard the cam timing.
Griff is offline
Old 01-31-2008 | 01:01 PM
Grog's Avatar
Lightbulb
Understood. I would guess then that clearances would get even tighter at max rpm when/if the valves start to float and when the pistons see their greatest travel in the bore.
Grog is offline
