What prop to run? And to much stern lift >
Old 02-05-2008 | 07:34 PM
Sick Stinger's Avatar
Brotherhood #1
Default What prop to run? And to much stern lift
I have a 26 velocity with a 572 c.i 900 h.p 10-71 bds blower. Bravo1 with 1.5 gears (i think). I have a 34p labbed bravo1 prop to try. Does this sound in the ball park. I hear 36 possably or a 32. So any input is great.
2nd part question. The boat had to much stern lift with the 650 h.p. 509 c.i. 250 blower motor with a hydromotive 28p QIV. How do i take care of this. How much does it affect control speed cruisin speed fuel consumption and planeing
-Mike
Sick Stinger is offline
Old 02-05-2008 | 08:47 PM
The QIV props give a lot of stern lift compared to Bravo Props. The Bravo will lift the bow more and stern less, so I think you're on the right track.
Griff is offline
Old 02-05-2008 | 08:55 PM
FeverMike's Avatar
A 32 Bravo will turn a little less rpm's than a 28 Hydro but you are in the ball park if both props are stock. Hydro's have stern lift and Bravo's wil carry the bow more. The Velocity hull with that huge flat pad will naturally lift the stern so I'd say try the Bravo 1 prop.
FeverMike is offline
Old 02-05-2008 | 09:17 PM
R Addiction's Avatar
AT Cult Member #3
What Griff said....
R Addiction is offline
Old 02-05-2008 | 09:49 PM
marinetrans's Avatar
With that much power and an elevated drive height, you may be into a 5 blade Maximus.
marinetrans is offline
Old 02-05-2008 | 10:25 PM
I hope you installed an "EJECT" button and ejection seat Thats a lot of HP for any 26 foot boat.
Griff is offline
Old 02-06-2008 | 05:39 AM
Brotherhood #1
Thanks guys. yea im going to try the 34 bravo, its labbed, and see what happens. I used a 24 bravo1 4 blade from Airtime (arti) just for test purposed i got to about 74 mph with it before it tach'd out but the bow and stern were better sitting. The blow out wasnt at all as bad but also the prop was much smalled then i needed to run.
Old 02-06-2008 | 05:41 AM
Brotherhood #1
As for the 5 blade Maximus prop thats totally out of the question. Its a Bravo 1 drive only with imco's for gears the power i have will eat that drive up in 1 outing, you know that Pete, so ill stay with the 4 blade for now just to hopefully make it the season taking it easy. Also Griff the boat is a true 26 now its the 280 Velocity, Its really a Steve Stepp ThoroughBred
Old 02-06-2008 | 06:44 AM
Hope you get the whole summer out of that drive, no turning drives into "trail mix".If you do we'll put a MAXX tower in it.
Old 02-06-2008 | 07:35 AM
Brotherhood #1
pete shoot me a pm on the cost of the tower maybe I should do it Before summer and ill be ready 4 the fall river poker run instead of on remedy even though it was a hell of a ride
Old Navy
Prop Talk
22
08-05-2008 04:24 PM
PARADOX
04-28-2008 11:30 AM
Back4More
Prop Talk
1
06-28-2006 12:03 PM
ROTAX454
Prop Talk
6
09-21-2005 10:34 PM
BAD-HABIT
14
06-10-2002 02:55 PM
