Older Clever, is thrust washer needed
I picked up a set of clevers in very good condition off ebay but when they arrived I was surprised by what appears to be a design that does not use a thrust washer.
Here's a picture of the back of the prop. The end is tapered (and nicked a bit, I need to get that machined) and it looks like it's not intended to be used with a thrust washer OR the thrust washer also has a tapered insert.
The part number is 48-74602A 23P
I assume these are old, possibly from a TRS drive but my boat really seems to like clevers and I would like to run this one since the 23" I have needs some major TLC. It's an '87 Donzi 22 Classic with a '96 Bravo 1. Runs 64 mph @ 4850 RPM on my current 23" clever, that's pretty good for an old classic V-Bottom and a basic 7.4L motor.
Ideas?
Ideas?
Originally they ran with 39701 front splined washer, a 39698 rear flat washer and a 52707Q1 nut.
[email protected]
[email protected]
So, are you saying it's been machined to work with the newer tapered shafts. In fact, I think the splines end long before the front side (thrust washer taper) of the shaft.
No it is factory. You need the washers and nut for the rear.
[email protected]
[email protected]
Ok, I understand now. I used a splined rear washer that came off the original rubber hub Clever that was on the boat along with the tabbed washer and locking nut. It's all pre-FloTorque stuff. It looks like this part:
That will work. the other part numbers are something else old school.
[email protected]
[email protected]
