Backstage pass to the LA boat show....... >
Old 02-09-2008 | 08:04 PM
CPPerformance's Avatar
Default Backstage pass to the LA boat show.......
Hey this is Brad with CP Performance, I am sitting at the booth right now surrounded by all kinds of cool stuff. I am here the entire show offering DEEP DISCOUNTS at the boat show ONLY. This is a must see boat show so if you got some time on your hands from now until the 17th, come down and see me!!
We are in Booth 209-211 (Right next to Performance Boats Magazine Boothdevil)
CPPerformance is offline
Old 02-09-2008 | 08:05 PM
Check this out the folks at Hardin Marine just dropped by the booth and pulled what I believe is the only HI-Performance big block ford exhaust system available today. NO MORE ADAPTERS! This manifold is patterned off of the same system that was designed for mercury hi-performance's HP500 (Gil). It has a brilliant black powder coated finish with individual water inlets at each exhaust port to eliminate any hot spots. Finally everyone out there looking to make some real power from a big inch ford I think this is the answer.
Old 02-09-2008 | 08:06 PM
Another exclusive from Hardin Marine. All billet CNC machined slim line cup holders for the ultimate clean look and modern function.
Cup holders never looked cool.............
Old 02-10-2008 | 04:59 AM
Nice!!!!
Dd24skater is offline
Old 02-10-2008 | 03:11 PM
Found this around the corner from the booth:
XPowerDrive
  • Direct replacement for stock Bravo outdrives
  • Tested to 1,535HP/1,296 ft. lbs. of torque with ZERO failures
  • X-Dimension adjustable up to 5 inches. Can be the same length as stock drive or up to 5 inches shorter.
  • Designed, engineered and built with the same technologies and materials used in Formula One race cars.
  • Intergrated oil filtration system and heat exchanger for compact packaging and exceptional cooling.
  • Complete self-contained 3 stage dry-sump system engineered to run with precise oil volume and pressure.
Old 02-10-2008 | 03:17 PM
Default Cant forget the Bikini Girls..........
Old 02-10-2008 | 03:22 PM
Default Not all the girls, but here are some more..........
Old 02-10-2008 | 03:24 PM
Old 02-10-2008 | 05:15 PM
Come by the booth to get your free poster!!
Old 02-10-2008 | 09:55 PM
PhantomChaos's Avatar
Sweet!!!!!!!!!!!!!!!!
PhantomChaos is offline
