Props 4 32 Outlaw??? >
Old 02-11-2008 | 05:07 PM
Question Props 4 32 Outlaw???
Alright guys I am looking for some good advice on what prop choice will be best? I am looking at a 32 outlaw with t540's approx 625hp per motor. It currently has b1's with the extension boxs and 26p 4blade bravo props. what do ya think??
BIGZXXL is offline
Old 02-11-2008 | 05:13 PM
If it's 1.36:1 ratio drives, that's probably about
the right setup.
JaayTeee is offline
Old 02-11-2008 | 05:17 PM
its 1.5 sorry forgot to add that
BIGZXXL is offline
Old 02-11-2008 | 05:24 PM
The motors must like running 6000 rpm then.
I have a simlar setup, but with less HP, and
can spin 32 Bravo's to 5450 ( rev limiter) rpm.
I have a relatively high X dimension, and
the best props that work on it are 32 maximus's
JaayTeee is offline
Old 02-11-2008 | 05:37 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
JT's right, w need more info.
[email protected]
bbladesprops is offline
Old 02-12-2008 | 01:18 AM
I haven't taken possession of this one yet so I am not exactly sure of the rpms just yet but I am pretty sure these props are not exactly right for the power. considering that it is still set up for the stock 454's. at risk of sounding like a idiot what exactly is the x dimension???
BIGZXXL is offline
Old 02-12-2008 | 08:53 AM
X dimension is the distance from the centerline
of the crankshaft to the bottom of the hull ( directly
beneath the engine).
This translates to how far the propshaft is below
the bottom of the boat.
JaayTeee is offline
Old 02-12-2008 | 09:05 AM
Cool
i run 28 lab finished, 515 hp per side. 32 outlaw and its for sale, going to cigarette.
sacaja is offline
Old 02-12-2008 | 11:35 AM
Sacaja give me some more details about the boat. may be intrested.
BIGZXXL is offline
Old 02-12-2008 | 02:28 PM
Default bigzxxl
i sent you a email, hope you got it?
sacaja is offline
