how can you tell the diffrence? >
Old 02-13-2008 | 10:22 PM
Default how can you tell the diffrence?
Between a regular 454 and a 454 mag, i have the black cap that goes over the carb, but it dosnt have any thing on its just plain black, the previous owner really didnt know just knew it was a 454
there any like special serial numbers or ways to tell with out having it dynoed
jlaudio29 is offline
Old 02-13-2008 | 10:55 PM
thanks for the info
Old 02-14-2008 | 08:21 AM
Pull the valve covers and check the head casting numbers.
ECeptor is offline
Old 02-14-2008 | 08:51 AM
ENFORCER24's Avatar
Look at the intake runners , mag will be squared off and you cant see much of the head where the intake bolts up , non-mag has peanut port heads and you can see alot of the intake face side of the head , just for grins , look for the red sticker on the starboard (driver side) valve cover , if it says its 330hp its non-mag , 365/385 and its a magnum
ENFORCER24 is offline
Old 02-14-2008 | 09:09 AM
BY U BOY's Avatar
Originally Posted by fredefox
Mag has 4 bolt main bearing caps and the non mag has two bolt main caps.
Thats not true, I have a 330 and it was a 4 bolt main.
Just above the starter there should be a plate with the serial number on it.
Post that # and im sure someone can look it up for you.
BY U BOY is offline
Old 02-14-2008 | 10:15 AM
Agreed, I have a '96 7.4L and based on the block casting number, 10237297, it's a 4 bolt main. The biggest difference between the 7.4L (454) and the Mag is forged crank (and rods, I think), large port heads (rectangular GM vs. small port oval GM, both are cast iron) and tall intake.
mjw930 is offline
Old 02-14-2008 | 10:29 AM
Don't forget cast vs forged pistons...which are the weakest link in the 7.4.
ECeptor is offline
Old 02-14-2008 | 12:19 PM
thanks for the replys guys ill have to check it all out, i dont store the boat at my house anymore so ill have to check it next time i see it.
Old 02-16-2008 | 08:01 AM
KAAMA's Avatar
I'm pretty sure the Merc 330hp/454cid originally was designed with a 2-bolt main block with all cast parts. It was in the late 1980's or so that the 330 came with a 4-bolt block vs a 2-bolt, but still had cast parts.
KAAMA is offline
bobo1
Scarab
2
10-15-2008 06:03 PM
thayes11
2
10-21-2005 04:10 AM
TELLefant
12
05-18-2005 11:59 PM
sonic31
Sonic
16
02-23-2005 06:02 PM
Strip Poker 388
02-20-2003 07:09 AM
