Pushrods
Old 02-15-2008 | 09:02 AM
ENFORCER24's Avatar
Default Pushrods
stock 330 , gen IV , stock cam
upgrading heads to 70's vintage 049 heads
stock valves / rocker arms / springs
do i need to get the adjustable pushrod to measure for correct pushrods
or do i stay with the stock size in the motor now
i'm gonna buy new pushrods either way , just dont want to buy things i cant use
ENFORCER24 is offline
Old 02-15-2008 | 09:59 AM
bcfountain's Avatar
Registered User
Default pushrods
i rebuilt my 330hp motor a couple years ago and used manly .080 heavy wall pushrods.i am running a crane cam,hyd,flat tapplet.i think as long as you stay w/hyd cam these pushrods will work.
bcfountain is offline
Old 02-15-2008 | 10:10 AM
ENFORCER24's Avatar
mines a stock cam , is it hydrolic?
Old 02-15-2008 | 11:35 AM
bcfountain's Avatar
Registered User
these pushrods should be ok.with a 330 motor you could probley get by with a thinner pushrod,but i would stay w/the .080 pushrods,not that much diffrence in price.my engine tells me as long as you stay stock,do not get to wild w/milling heads,decking the block,milling the intake,you should be fine.as you know most 330hp motor,s have a cast crank,and small[peanut heads].,two bolt mains.you can probley make about 400hp with this block and be ok.hope this helps.brad
Old 02-15-2008 | 11:39 AM
ENFORCER24's Avatar
i was mostly thinking about the length of the pushrods , not the thickness.
the peanut heads are going to be my new boat anchors , there being pitched for large oval cast iron heads , cam remains the same and exhaust is tubular headers , intake will be hi-rise single plane with a 750 holley , i'm guessing with the stock cam i should be around 380-400 hp
if it doesnt grenade the first time i start it (my first build)
Old 02-15-2008 | 11:44 AM
2 winters ago I put a set of 781 heads (large oval port, open chamber just like your 049s) on my 1989 330hp 454. I used the stock push rods and have had 2 trouble free seasons on them.
Yes, your lifters are hydraulic.
ECeptor is offline
Old 02-15-2008 | 11:45 AM
If you are keeping the stock cam and reusing the lifters, make sure that they go back in the exact hole that they cam out of.
If you are getting new lifters, make sure you break them in properly or you will flatten a lobe on the cam and that will hand grenade a new motor.
If everyhing is staying constant, then you can go back with the same length pushrods.
You aren't installing roller rockers and studs. You might as well while you have it apart.
Good luck with your project.
I just built one almost exactly to what you are doing, but I put in a bigger cam.
http://www.offshoreonlyclassifieds.c...o21326-en.html
jeff1000man is offline
Old 02-15-2008 | 12:10 PM
If you are going through all that work, you should install a new and bigger cam as well. You can get a new flat tappet cam and lifters for $200.
Griff is offline
Old 02-15-2008 | 12:14 PM
I agree. .560 / 240 - 112 or pretty close, is a great cam in a 454. I prefer solid lifter, but $200 is baout right. Sometimes less, depending on the cam grinder.
Old 02-15-2008 | 12:17 PM
ENFORCER24's Avatar
the way my brain works , i dont want to go too nuts with the cam / top end , cause i still have a cast crank , cast pistons , thin rods , and about 500 hours on em
as with all boaters i want to find the most horsepower and the least chance for missing a weekend on the water come spring
